Originally Posted by katflap
Thanks detours, excellent info
I will definitely be taking a closer look at the thermobob. I wonder if the hose size connections are the same as the RX3.
I think we would have to remove the thermostat from our RX3 thermostat housing and then connect it somewhere between the cylinder head and the thermobob. By doing this our temp sensors will then be before the thermostat, where they need to be ![Smile](images/smilies/nod2.gif)
You're right, Kat.
We could remove the stock
thermostat, and relocate the stock thermostat
housing closer to the outlet from the cylinder head. Then we could place the Thermo-Bob downstream from the stock thermostat housing, somewhere near the original location of the stock thermostat housing.
Of course, we do need to contact Watt-man, and see if any of his different Thermo-Bob kits will fit the hoses of the RX3.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
![Wink](images/smilies/windfk.gif)
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
