Originally Posted by fishman10
i've also adjusted alot of the play outta my clutch ,after some initial stretching,, and now i can get nuetral pretty easy.. Thing i dont like, is the clutch engages way out at the end .Not sure if this is something that i can adjust out by using the bottom adjuster ..i much prefer the clutch starting to engage about half way out ,,hope that makes sense.
You
won't be able to move the friction zone of the clutch with the either the bottom adjuster, or the top adjuster for the clutch cable. The location of the friction zone is determined by the length of the push rod which expands, and contracts the clutch discs. The clutch in my Zongshen Sierra 200, and the Yamaha TW200, have a provision for this adjustment. However, the Zongshen RX3 does not.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
