Old 06-02-2013, 06:36 PM   #110
pete   pete is offline
pete's Avatar
Originally Posted by SpudRider View Post
Some of the CRF450 owners are installing a TRX450, 3-ring piston in their bikes.
http://www.thumpertalk.com/topic/778...-in-a-crf450x/
thats a better looking piston but still a short skirt..
the WR250R has a long piston uses the same bore & stroke
as the WR250f but is only a 4 valve motor... don't think
you could machine a 5th valve pocket in the piston...
with the right valves / piston / compression ratio theres no
reason you couldn't make the motor last a lot longer.
I looked at the WR250R but they are a 2008 onwards model
and hold there prise... the WR250f takes a rekluse clutch..
edit.... just found this for a WR250F.. http://www.ebay.com/itm/350298522813...#ht_1134wt_932
full skirt 3 ring piston ... high compresion ,but a few base gaskets will sort that..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
