LOTS of LIFAN GY-5 parts AND motor parts
Everything you see here as well as a front wheel and a COMPLETE PARTS MOTOR (167FML pushrod version) I can pick parts off of as needed. I may have other parts that are not visible in the photo, PM for condition of parts or better photos I'm letting them go cheap to those in need. :wink:
http://i1154.photobucket.com/albums/...psaef434b1.jpg |
Shipping from AK or MT? I'd be interested in the pushrod motor, but shipping might be prohibitively expensive for me.
Do you have a good set of plastic side covers? Got a close-up pic of them?
http://i1154.photobucket.com/albums/...ps4f2f809a.jpg
http://i1154.photobucket.com/albums/...ps9dd54f34.jpg The upper white one has a little crack below the rear screw hole and was damaged by a forklift when it was being unloaded from the barge http://i1154.photobucket.com/albums/...psd2ddad14.jpg Shipping is from alaska so the entire motor would probably not be possible, I think the valves and bore have been damaged from getting stored out side anyways |
I think that those would require more fab work than the GY150 covers I already bought. Is the tank plastic? Got a pic?
I am planing on using the gas tank for the buggy project actually
Ok, thanks anyway. I can't think of anything else I can use.
How much would you let the motor go for?
The motor has a bad top end from sitting out side and shipping from alaska would be $100+
I'd be interested in the front headlight housing if its still around... I have a Roketa db 05 and the housing is cracked in two. I see it in your o.p. but barely. Any chance on a front and back photo..?
Is the harness i spy complete? If so how much shipped to 60473? Thanks!
I think that is a polisport mmx headlight
my first wiring harness failed and it took over a year of searching to find one that would work because they changed the wiring harness between years and countrys that the bikes were shipped to ( still had to change the turn signal wires on the bike to match this one). if you would like I can take pictures of all the connectors and you can compare it to yours. |
ifplugs dont match up thats not thebiggest issue forme to dealwith...LOLilike bullet connectors...easier to crimp than the stupid molex plug style....although i have acess to those too....LOL |
Hello Wild_Alaskan I was wondering if you had the throttle grip assembly for sale? I also need the choke cable, headlight plastic, and front brake booster if you have it available. Thanks man!
