My old bike i had chain soaking in gear oil but this talking of using wax got me thinking and a quick google search revealed this: http://www.motosport.com/product/?ad...segment=badger best part is cause its a wax dirt wont stick to it.
Also came across this one https://www.amazon.com/DuPont-Teflon.../dp/B00KMMFE8Y
Wax works great but I highly recommend using a double boiler to heat it or you risk a fire.
The 2 links i posted was for an aresol spray.
Thanks whats the max rpm of motor i believe i read where it makes max hp at 7000 rpm
I was watching a motocheese video and he was talking about timing as well as the aftermarket cdi box that has adjustable advance/retard
My engine will wind out to 8000rpm in the lower gears. I just have a problem reaching 70 because I am a big guy. I am pretty sure a more normal sized human could do so with my bike.
I am pretty sure with a basic port cleanup and no real serious porting work it will break that 70mph, but I still wouldn't want to push this bike much further than that, plus I would definitely want to drop the rear sprocket a couple more teeth to really make it ideal for highway use. |
Sprocket Calculator
Here's a link to a good sprocket calculator. http://woodsware.aciwebs.com/gears/ Type in 2016 in the filter and the 2016 Haosen Hawk 250 will come up in the list.
