07-06-2017, 12:21 PM | #46 |
I see, thanks
07-08-2017, 01:33 PM | #47 |
Well, I figured I'd bite the bullet and order a muffler from CSC for the listed 199.95. Sometimes it just doesn't work out when you experiment on mechanical stuff, I get it. So I log in to CSC this morning....and my muffler has gone up to 258.95.
I'll stick with what I have. It's not THAT loud.....and if I ever want to reverse the process, I'll have my muffler welded back on to the tailpipe. I didn't cut any length off so I should be good. EDIT! Gotta love Gerry. I called them to order a couple of the sprocket washers and he's going to nose around and see if he has a used muffler laying around and will get back to me. Fingers crossed!
07-10-2017, 10:34 AM | #48 | |
07-10-2017, 10:57 PM | #49 |
2lz...Yep, cause putting out 3 bills ain't gonna happen. I agree
07-14-2017, 04:05 PM | #50 |
Option Dos'
Well, since Ive actually started to enjoy beating my head against the wall....I thought I'd try yet another muffler on the RX3.
With the mid-pipe cut from the stock RX3 muffler, the CRF230 compatible muffler that the TT250's, Hawks, Bashan bikes CG bikes are using, slipped right on perfectly. I just had to move the pre-existing bracket I whacked off the stock muffler and reformatted the plastic side piece a little. I can tell you that it passes WAY more gasses than the stock unit or the little one I had on previously. You easily get hit with puffs standing 8 feet behind it. Louder than stock? Yep.....but not by a bunch at idle, by any means. I think it's actually quieter than the little one I just took off. Much deeper tone, that's for sure. It gets kind of loud when you're revving it but has a nice "bobble" at idle. As long as it settles down at cruise speed, it's all good. Now, if my countershaft washers show up today, I'll take it out for a shake-down cruise and see how it goes. If I like it and it doesn't interfere with the bag bars, I'll order a black one and put this one back on the TT. In the meantime, Mrs. 2LZ TT250 isn't going anywhere for a little while. ;-) EDIT: Washers showed up and I took it out. Wow...I'll have to run it against Mrs. 2LZ stock RX3 again. Even if it's not "faster", the throttle response at lower R's is noticeably improved. There is a DEFINITE increase in usable torque between 3500-5000. Just cruising at low speeds, I don't feel like I have to ring its neck to get some power. Ordering a black setup today. At cruise, it quieted down nicely.
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 05-26-2020 at 12:25 PM. |
Display Modes | |
