07-19-2016, 10:15 AM | #16 |
How much was it for each cable? I'm sure you are right around the cost of a ('cheap') Hydraulic setup already... and you would only have to change out a few cents worth of DOT4 or Mineral Oil every 2 or so years with a Hydraulic Clutch
07-19-2016, 11:04 AM | #17 |
Check your pivot hole in the handle where the cable end sits. Sounds like a burr not allowing the cable end to pivot. That was an early Victory issue. "The Dreaded Burr".
07-19-2016, 03:00 PM | #18 | ||
and a vid... sounded mean... Last edited by bogieboy; 07-19-2016 at 09:16 PM. Reason: edited for speed inaccuracy |
07-19-2016, 04:28 PM | #19 |
Holy cow! That's an animal! :-)
04-05-2018, 10:21 AM | #21 |
interesting that you ask GlennR... i just installed one LAST NIGHT...LOL i had a random left hand master cylinder from an old john deere atv in my posession, and installed it with one of these... sooooooo nice and smooth.... took almost a half hr just to bleed though.... i can post some installed pics tonight...
04-05-2018, 03:50 PM | #22 |
That style of slave cylinder is a pain in the butt to bleed. I have done one so far, and the best method I have found for them is to elevate the slave above the master somehow, and then bleed it uphill. Really awkward to do without a bleed screw too. Another method that worked fairly well was to set the slave on a rack or tray over something to collect dripping brake fluid, crack the banjo just enough to start a slow leak, and gravity bleed it. This method takes forever though.
In either case, pre-filling the slave with a bit of fluid and cycling it a little to get the air out will help immensely.
04-05-2018, 05:42 PM | #23 |
Cables are so much simpler. Otom makes a nice brace that stops the flexing of the retainer issue and makes the pull a tiny bit lighter:
I have a Karoo trials bike that I never ride because of the broken hydraulic clutch. It's just a bigger pain than it's worth. |
04-05-2018, 09:11 PM | #25 | |
04-06-2018, 10:12 AM | #26 |
Must....resist....clicking.....
04-06-2018, 01:29 PM | #29 | |
04-06-2018, 01:30 PM | #30 | |
Well... it's Taobao. 6 pictures doesn't mean you get six of them. There are probably some less expensive vendors, I just posted the first one I found. I'll see if I can find the actual link I bought from. Seems like it was $8 or $9. |
Display Modes | |
