Old 06-19-2015, 08:58 PM   #46
bucklove   bucklove is offline
https://goo.gl/photos/WXC6rxHPA3HkeujS6
Vin tag picture
Old 06-19-2015, 09:01 PM   #47
https://goo.gl/photos/DhsTCAC2LUb65is8A
Forward /Reverse gear shifter
Old 06-19-2015, 11:11 PM   #48
humanbeing's Avatar
Maybe similar to ebc FA067
Old 06-19-2015, 11:49 PM   #49
https://goo.gl/photos/p6EjuMAwPBo3aAw88
I just looked at a set of them on EBay and they measured 85mm x 43mm x 8mm and mine are 85mm from center to center on the holes I forgot what it was top to bottom.... they seem similar... thanks Humanbeing!!!
Old 06-19-2015, 11:51 PM   #50
It would be nice to have a manual!!! I checked with CHINESEATVMANUALS.COM and no luck. He told me my engine was a Yamaha Timberwolf copy and to get that manual... I'm not sure what he based that on...
Old 06-20-2015, 03:04 AM   #51
humanbeing's Avatar
Because bore & stroke are the SAME. Manual: http://www.mikekekich.com/92-98%20Ti...e%20Manual.pdf
If it's as Timberwolf, then the clutch fraction plate = 21V-16321-00 (I.D 95mm O.D 125mm) x5
http://chinariders.net/showpost.php?...8&postcount=26 showed a great deal [SR150 (6pcs pack) ¥10.00] from parts wholesaler.
Old 06-20-2015, 07:45 AM   #52
Thanks Humanbeing!! I have noticed that thr drive is a shaft in the manual and mine is a chain!! I'm getting closer!!!
Old 06-21-2015, 01:27 AM   #53
Matthew, try hitting eBay for "atv brake pad" and see what happens. Filter lowest price first, and look through all of the pics until you find a match.
Old 12-21-2022, 12:00 PM   #54
jonis832   jonis832 is offline
Originally Posted by bucklove View Post
I have a 2008 JIANSHE JS250 ATV-8 SPORT and I can't find parts for it...only the JIANSHE JS250 ATV-3 and 5 utility models...it like it just dissapeared into thin air!!! Am I looking for the wrong thing??? Is it called something else??? What's up??? HELP PLEASE!!!!
Have you visited the Kemimoto store and are you sure you can't find the Polaris general accessories from there?
