Old 06-15-2014, 11:19 AM   #46
Originally Posted by humanbeing View Post
Puller 拉码 (dyslexia or lazy guy write it as 拉"马")
3-in-1 http://item.taobao.com/item.htm?id=7418226241 tool that suits most clone(s).
Thanks HB!
I searched those pages and found several different pullers that I'd like to have.
Old 06-15-2014, 08:15 PM   #47
recracer   recracer is offline
recracer's Avatar
Thumbs Up
Thanks HB!
Me also Thank you . Beats Snap-On prices .
Old 06-22-2014, 05:26 PM   #48
recracer's Avatar
I decided to weld on a timing extension. The case of the flywheel did not mind at all . I did not have gas ,so in used flux core on the mig . I needed a way to smooth it to a true radius and missed a craftsman 101 6 x 18 metal lathe for 300 dollars and 4 miles from my house . 3 Reasons , not owning a truck , being lazy tired after work Thursday and Friday, then thinking I had time to wait for my wife and her Saturday chores . before I took her ford edge from her . I ended up putting a abrasive disc on the table saw and careful fence setting to grind the radius. Not the most beautiful timing tab , but the bike runs ,with the carb still at this point . So about the extra timing with the carb in place . The bike seems to rev freely and pull harder in all gears . With my current gearing of 15 and 45 18inch rear dirt wheel. riding at 7000rpm it still has good pull with no complaints to 8000 @60mph across the board it feels perky . Oscilloscope will tell me if the timing tab is good enough for the Fuel Injection .
Last edited by recracer; 06-22-2014 at 09:12 PM. Reason: had wrong rear gear listed ,it is 45 tooth not a 46
Old 06-22-2014, 08:28 PM   #49
Very resourceful! I was thinking that you might also be able to do that with an abrasive bit in a router table, but your idea worked well.
Bummer about missing the lathe.
Old 06-24-2014, 11:25 AM   #50
recracer's Avatar
I will need a Throttle cable to fit this , if I remember correctly . the zong sierra has this style pull .
Old 06-24-2014, 12:27 PM   #51
You are correct, Racer. Here is a link to a throttle cable for the Zongshen 200GY-2 sold at Taobao.
http://item.taobao.com/item.htm?id=1618768836
Conversely, the Yamaha TW200 uses two throttle cables, a push cable, and a pull cable.
Old 06-24-2014, 01:48 PM   #52
recracer's Avatar
Thank You Spud. The control end even looks right for my throttle
Old 06-24-2014, 03:26 PM   #53
You're welcome.
Old 06-28-2014, 05:42 PM   #54
recracer's Avatar
Thanks to spuds quick throttle cable link ,It is on the way . This weekend I decided to start putting things together . CDI will be DC with no timing , factory was AC CDI with integral timing . On the fuel injection ,the control module will be charge of timing . pics bike stripped down , what's coming off and what's going on .
Old 06-28-2014, 11:55 PM   #55
recracer's Avatar
Progress
Old 06-29-2014, 01:03 AM   #56
That's progress, indeed.
Old 06-29-2014, 08:59 AM   #57
edtardo   edtardo is offline
edtardo's Avatar
Can't wait to hear the results of this project.
NewStar DB 200
Facts are meaningless. You could use facts to prove anything that's even remotely true! --Homer Simpson
Old 07-02-2014, 12:53 AM   #58
Was there a recommended O2 sensor position? What are your air filter options?
Old 07-02-2014, 07:22 AM   #59
recracer's Avatar
Yes . I have this in pdf files .
For engines over 150 cc displacement, 60-260mm is recommended. Oxygen sensor is bestly in vertical orientation, at least 10 degree downward of the sensor element is needed
For the air filter, I just need a smaller size . The cone filter from the carb is bigger . I may clamp it down for now . Throttle cable should arrive today ,DHL Express. Lately DHL has been the fastest delivery from china .
Old 07-02-2014, 11:41 PM   #60
recracer's Avatar
Fuel tank setup
New petcock to be installed and an extra vapor vent . The original hole in the tank was not fully opened , I am not sure how the oe petcock even worked . I used a 4 flute End Mill bit chucked in a drill to remove the extra plastic . I found a 3/8 barbed 1/4 pipe thread fitting for the vapor vent ,then drilled and tapped the tank to 1/4 pipe thread. I added plastic tubes to get the vents to the top of the tank . small one vent the petcock filter bowl and the larger is petcock vapor separator. I will cut the tubes just below the gas cap.
