Old 10-05-2018, 08:09 AM   #16
goat67   goat67 is offline
goat67's Avatar
Originally Posted by AresROC View Post
Thanks the gas tank cover is one of the first things I checked for vibration noise. The brace seems to be fine and tight, but I havn't checked the horn yet.
Tight is not the issue make sure it is not coming in contact with the motor I had mine positioned so that it would at times make contact.
2016 Brozz
Old 06-15-2023, 09:41 AM   #17
Desuboi941   Desuboi941 is offline
Took the bike out for some top speed flat out runs.
Seemingly after the bike ran over some dirt/rocks, bike is making a rattling/grinding noise. Video:
I parked the bike and checked for loose bolts. All were tight except the exhaust header can be tightened a bit more.
Rev the engine in neutral and the noise seems to be coming from the engine. Sounded as if a rock was inside, but it was not making the noise all the time, and from time to time the noise sounded really bad as if something is grinding.
I also noticed the valve noise is getting louder with its ticks.
Anyone have any idea what is causing the noise from an engine with 30 miles on it???
This is when the noise started:
LMK
Hey man, my hawk is making he same noise, only on wot in high revs or at max speed. When I go 50, it starts buzzing or grinding whatever, with the more I push it, the more and harder it buzzes. If I go up to 60, the bike will do fine, as I give it more the speedometer starts going down but I feel as if I'm going the same speed. I dide use synthetic to run it twice but I didn't ride on it. I've been using t4 or t6 10-40 or 15-40 ever since. It runs smooth down low. There's a slight inconsistency in the idle, but it sounds good. I was thinking it might be my speedo cable. Bit idk I'm hoping it's not too engine. Have you found out what it was?
Old 06-15-2023, 09:47 AM   #18
Check to make sure its not a loose heat shield on the exhaust
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
2017 Honda Fury
bashan, bsr, engine, noise
