Old 03-06-2021, 03:55 PM   #46
idle_purr   idle_purr is offline
idle_purr's Avatar
Originally Posted by Bill Hilly View Post
I trimmed my fork guard to better accommodate the speedo wires. I am going to try a picture. http://imgur.com/a/ccWoQ0y
Some reason I dreaded putting the fork guards on, and it was a bi*ch too. The brake cable was just so stiff but I got got it to go, though I wasn't able to use the lock washers because I couldn't get the screw to grab for the life of me. I just thread locked it good and tightened it without the locking washers. The speedo side was PIA because there was no slack for the cable. I too thought of trimming my right fork guard but then just came to the conclusion that the speedo cable is just thick because of the outer rubber shielding, the wires inside are a lot more flexible. That gave me some peace of mind and I did kind of loop shown below. Everything seemed to have JUST enough slack, hopefully I have no issues, if so I will definitely be calling for a replacement.
NO HILL TOO STEEP NO MUD TOO DEEP
The Brozz | The Hawk Upgrades, Accessories, Etc...
Assembly Checklist: Brozz 250 | Hawk 250
~idle_purr
Old 03-06-2021, 04:17 PM   #47
It may have been in the way I had the bird's nest of wires stuffed up under my headlight,but I just couldn't get enough slack on my speedo wires. If it's not just the camera angle ,it looks like yours is not under as much strain as mine would have been routed through the very bottom.. Do you use a Photo service like Imgur, or Photo Bucket when you post ?, Or do you use the direct method as in the sticky about posting pics ? I tried the direct method, and it says that the pictures exceed the size limit, or something similar to what I just said.
Old 03-06-2021, 04:35 PM   #48
idle_purr's Avatar
I use imgbb I upload the photo there and then get the bb [img] embed tags. I always resize my images to have a max width of 750px
~idle_purr
Old 03-06-2021, 04:39 PM   #49
[QUOTE=idle_purr;354953]I use imgbb I upload the photo there and then get the bb [img] embed tags. I always resize my images to have a max width of 750px[
Thanks, idle purr, I am getting it figured out.http://url=https://ibb.co/VCVb8bf][/url
Old 03-06-2021, 04:47 PM   #50
Just a note for you guys.. i found that the connection points on the fork for the fork guard to clip against were in the wrong place when delivered. When i changed my fork oil and re-installed the fork legs i was able to turn each so that they oriented properly.
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
2017 Honda Fury
Old 03-06-2021, 04:54 PM   #51
idle_purr's Avatar
Are you referring to the white plastic brackets that the fork guard slides in to?
If so, I just loosened mine and adjusted them.
~idle_purr
Old 03-06-2021, 04:55 PM   #52
Yeap, thats them
2019 Beta 430 RRS
2017 Honda Fury
Old 03-06-2021, 05:10 PM   #53
idle_purr's Avatar
Yeap, thats them
not to go too far off topic, but is your 428 X Ring chain a 130 link? I got a NICHE 130l 428 X-Ring and was not entirely sure if it was an exact fit or if i'd have to cut some links. I have the 17F 46R gearing.
~idle_purr
Old 03-06-2021, 05:21 PM   #54
Mine was a 128 link. You'll probably want to cut a link or 2 out so that you have more adjustment lines left. I cut 1 link out when i swapped the rear to a 42T
2019 Beta 430 RRS
2017 Honda Fury
Old 03-06-2021, 05:32 PM   #55
By the way, you'll love the chain.. especially if you had kept the stock chain long enough to have to adjust it almost daily, the new chain is a god-send as it stays in great shape and doesn't stretch anywhere near the frequency of the stocker. The only pain in the butt was attaching the master link clip over the little rubber o-rings, i wound up using a vice grip tightened lightly to get it on (didnt have the chain breaker tool at the time which would work even better to squeeze while putting the clip in place)
2019 Beta 430 RRS
2017 Honda Fury
Old 03-06-2021, 06:55 PM   #56
idle_purr's Avatar
Well I just tried to gas up the bike and start it with no luck, then discovered gas was running right through the carb, also noticed my gas gage doesn't seem to be working, but I might not have enough gas in it, not sure, made a lot of progress but going to bed feeling defeated tonight...
EDIT* Had to adjust drain screw, then she started up and I tuned the carb.
The defeat is victory now
~idle_purr
Old 03-06-2021, 07:14 PM   #57
Spins   Spins is offline
Spins's Avatar
Well I just tried to gas up the bike and start it with no luck, then discovered gas was running right through the carb, also noticed my gas gage doesn't seem to be working, but i might not have enough gas in it, not sure, made a lot of progress but going to bed feeling defeated tonight...
What do you mean the gas is running right out? Where? How much fuel did you add?
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 03-06-2021, 07:19 PM   #58
idle_purr's Avatar
I am not sure how much I added maybe a half a gallon, when I turn the pet cock on gas starts leaking from a hose at the bottom down by the skid plate. I assume its coming from the carb. I couldn't see much it was dark in my garage.
~idle_purr
Old 03-06-2021, 07:25 PM   #59
Spins's Avatar
Him? Perhaps the screw on bowl isn’t tight and it’s draining. IIRC There’s only one hose running out of the carb and that’s the bowl .
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 03-06-2021, 07:29 PM   #60
idle_purr's Avatar
Sounds about right, it's definitely going through the carb and draining out of the bowl. I don't know much about carbs so I am not really sure where the drain screw is, or how it got tampered with.
Must be these carbs drain through a hose.
~idle_purr
