Old 03-21-2015, 01:46 AM   #1
Adjuster's Avatar
Valve Adjustment
What do you guys think of this?
Old 03-21-2015, 02:55 AM   #2
humanbeing's Avatar
sell ice to Eskimos
Old 03-22-2015, 08:01 PM   #3
Tvnacman   Tvnacman is offline
Send a message via Skype™ to Tvnacman
http://www.nycscooterparts.com/#!pro...ol-(nycsp0051)
For tech help call John 2125980016
Old 03-23-2015, 11:50 AM   #4
I would never guess; I always use a feeler gauge.
I use a square head screw (which is called a Robertson), and I have it twisted into a marrette electrical connector. It works well.
Old 04-04-2015, 11:09 AM   #5
I agree with Weld. It is not difficult to use feeler gauges, and they are far more accurate than guessing.
I also use a Robertson deck screw inserted in a wire nut.
Old 04-04-2015, 11:14 AM   #6
I would buy this tool if I could find it at a decent price.
Old 04-04-2015, 12:03 PM   #7
You're a gentleman for referring to it as a Robertson, Spud.
Old 04-04-2015, 12:10 PM   #8
tortoise   tortoise is offline
Probably works just as well as the expensive stuff.
Tempted to try the hot technique.
Old 04-04-2015, 02:13 PM   #9
Mudflap   Mudflap is offline
The hot technique works for some engines but not all. In most engines the valve lash grows as the engine heats up so if you set it to zero when hot you'll never get it started when cold since the valves won't close.
Old 04-04-2015, 03:17 PM   #10
humanbeing's Avatar
Originally Posted by tortoise View Post
Probably works just as well as the expensive stuff...
http://item.taobao.com/item.htm?id=38416302208 http://item.taobao.com/item.htm?id=38270223935 < $2 in motherland
Old 04-04-2015, 10:37 PM   #11
Thanks for posting the good links, Humanbeing.
Old 04-05-2015, 11:51 AM   #12
Those will be part of my next purchase.
Old 04-05-2015, 03:23 PM   #13
139QMB 50cc screw adjuster square top measures around 3mm . . nut is 9mm . . so the H9 tool should be compatible.
Per this parts listing, all the GY6 50/125/150cc engines use the same adjuster screws and nuts.
Not really a great value, but the Motion Pro gauges work very well . . .002 inches for cold 50cc . . .004 inches for cold 125/150cc.
Since GY6 are a frequent gremlin and while access is open, loosen clamp and slide carb back from manifold, scrape/file any mating casting bumps, and apply a very light smear of silicone grease (not RTV sealer) on the join surfaces to deter leaks. Replacement resource (single vacuum port).
Also only takes a few minutes to test battery and charging volts to monitor those gremlins.
Old 04-05-2015, 04:40 PM   #14
Adjuster's Avatar
The tools are available on Ebay for less than $10 with free shipping. Think I saw them as low as $7.
Old 04-05-2015, 05:13 PM   #15
Adjuster's Avatar
Here it is.
http://www.ebay.com/itm/Cars-Trucks-...394869&vxp=mtr
