Old 08-26-2020, 06:05 PM   #1
XLsior   XLsior is online now
Poor Mans Pool Noodle Cylinder Hone.
Hi, Was going to put this in my XL185 with a Zongshen CG250 swap project thread but I think this information is general purpose DIY maintenance that might help.
My used CG250 had weak compression so I removed the top end to find a fair bit of piston slop and a glazed bore. Clearly it was burning oil.
I checked Aliexpress, piston/ring kit was $25AUD and a new Jug/piston/ring kit was about >$100AUD (shipped)
I decided to try the low cost approach first so went with piston/ring kit went with this...
https://www.aliexpress.com/snapshot/...ctId=752466407
So what to do about the glazed jug...
purchasing a 3prong or dingle hone would defeat the cost saving by not getting a new cylinder kit.
Ive seen people use red scotchbrite but I wanted something more consistent.
So looking around my home MacGyver style, I found a section of pool noodle, some masking tape, a sheet of 600grit wet dry sand paper and some lube oil (whatever you got)
(Disclaimer) this will work on any small engine cylinder to de glaze and apply a cross hatch. It is not a hone to re bore...
Process:
1. wrap the noodle with tape sticky side out.
2. roll the sandpaper around the noodle. Half a sheet was enough for me.
3. lube the sheet and cylinder and insert your hone*
4.by hand using a IN and Twist / OUT and Twist action. clockwise/anticlockwise doesn't matter but be mindful of the sandpaper sheet overlap.
5. Check results every half a dozen or so turns.
6. When you have achieved the desired result you're done and now your new piston rings should seat properly.
Remember this is just a poverty spec solution. Do so at your own risk.
Cheers, XLsior
Old 08-26-2020, 06:12 PM   #2
Sorry The Aliexpres link didn't work but it was listed as a
Racing Molybdenum 65.5MM 15MM Piston Ring Gasket Kit CB250 CB200 200CC 250CC 165FMM ZongShen Loncin Dirt Pit Bikes Motorcycle
I measured the diameter of my original piston before ordering to check it wasn't a 67mm
Old 08-27-2020, 02:01 AM   #3
Additional Notes:
The ball and 3 prong store bought hone sets appear to range from 120grit to 320 grit.
So my 600grit wet dry sand paper is mild in comparison. 400grit might be a better choice. however due to this it is very unlikely you will cause any damage.
Also I believe the optimal cross hatch angle is 45*, so you will have dial in your own IN and Out Twist action to achieve something close to this.
Old 08-27-2020, 11:12 AM   #4
Genius! Love it! This is the true essence of being a China Rider, if I've ever seen one......
Congrats on the great (and dirt cheap) solution!
Oh....and I love the self-draining workbench. ;-)
Old 08-27-2020, 02:25 PM   #5
franque   franque is offline
That's great! I'm glad you've decided to post here!
Old 08-27-2020, 04:57 PM   #6
Thanks 2LZ,
I put creases in clothes, ain't got time to iron them out.
Old 08-27-2020, 08:26 PM   #7
humanbeing's Avatar
65.5mm (15 pin) 223 is not a typical CG config
The altenative http://chinariders.net/showthread.php?t=14466 if can't find from elsewhere. The offical consolidation service https://world.taobao.com/helper/know...m?&kid=6551702 to OZ
https://item.taobao.com/item.htm?id=608837686639
Old 08-27-2020, 09:00 PM   #8
Hi Humanbeing,
you are correct it is not typical.
My engine is marked ZS167FMM... which would indicate a (1)single cylinder ans (67) mm bore.
But as we know this is China manufacturing.
It really would be a CG230*
This is why it is important to measure the piston before ordering a replacement.
The cylinder, piston and wrist pin from my engine match the dimensions in your provided image.
Old 08-27-2020, 09:09 PM   #9
Actually I measured the cylinder height to compare.
there is a difference 29mm/33mm and 76mm/80mm.
Conclusion: China
Old 08-27-2020, 10:52 PM   #10
humanbeing's Avatar
Stock Yinxiang had that 65.5 config
Alternative way to tell which is which
Old 08-27-2020, 11:11 PM   #11
Good to know.
153mm push rods confirmed.
250cm3 cylinder with a 65.5mm piston.
I still advise measuring the piston when all you decide to do is purchase a new piston and rings and hone your existing cylinder.
Old 08-28-2020, 11:36 AM   #12
humanbeing is like our version of Yoda. Has all the info and shows up when needed to spread his wisdom. ;-)
Old 08-28-2020, 05:51 PM   #13
I double checked the wrist pin measurement as Humanbeing suggested my engine was weird config.
Pretty sure it is a standard 67mm with 16mm pin.
the wrist pin size is what thew me...
I have adjusted my intended piston order and have also purchased as set of digi measuring calipers to avoid any more miss measurements.
It's why sharing this sort of information helps everyone. Catch these kind of mistakes before they are made.
