05-13-2019, 08:09 PM | #16 |
I ordered some carbs, jets cables and throttle parts - I will post soon a link etc if that is OK?
05-13-2019, 08:24 PM | #17 | |
Input as to what should be there is listened too. Jets and pilot jets everything you should need will be included as well as option to have manual or cable choke etc. |
05-17-2019, 07:06 PM | #18 |
So i got a used PZ30b for about 3 usd dollars. Of course i need to rebuild/rekit it.
So i wonder what kind of kit i need?? |
05-17-2019, 07:10 PM | #19 |
Yeah, feel free to include a link or two to parts for this carb. It's on topic. I thank you for asking though, very respectful.
05-17-2019, 07:18 PM | #20 |
Most of that stuff doesn't actually look that bad and could be cleaned up. Most of the parts you can use a standard PZ30 kit for. If the accelerator pump diaphragm is torn it might take a little searching. I haven't looked too hard for the parts myself, but it would be a good idea to figure out where to get them from.
05-17-2019, 10:43 PM | #21 |
I have a question about the pumper carbs. Does the additional fuel from the pumper circuit lasts only one time or the circuit is active as long as the throttle is twisted?
Does the circuit gives one dose of fuel or maybe vacuum sucks the fuel through pump circuit even after the pump has injected the fuel dose? |
05-17-2019, 11:16 PM | #22 | |
I guess in technical terms the nozzle could add a teeny weeny level of fuel al the time since it is an open circuit to airflow, but it wouldn't be anywhere near enough to have any appreciable affect. The hole on the end of the nozzle is so small I couldn't really get a good picture of it, if that gives you a good idea. It is literally a pin hole.
05-18-2019, 09:40 AM | #23 | |
05-18-2019, 09:41 AM | #24 | |
05-18-2019, 09:53 PM | #25 |
As a set a 1 stop place what would you think is the best way to purchase a kit? with what options etc?
PZ30B with fuel line and filter (non cable style) Dual cable and fast throttle (Not TT250 suitable) Hand grips Pilot Jets 42 45 48 50 (I'm assuming after 1st tune kit or should I change that?) Main jets 103 108 118 (these are in between sizes to 1st tune kit) Option to buy with the kit a choke cable and bracket for carb More jets in case folk didn't start with the 1st tune kit? Also there are possible options to just use stock style quick turn throttle (I'm not sure if Hawk etc stock is what I am use to being stock) I have a dual cable that MIGHT suit the TT250 so there's a possibility for TT250 owners. Also quick turn/1/4 turn throttle has the ability to be used on stock PZ30 carb (cable and throttle part) Could even add a choke cable to this set up. So many options! |
05-20-2019, 05:59 PM | #26 |
Well i was able to get a rebuild kit for the P30B. At first i was afraid of the price, because the last kit i bougth was for an original VM26ss, the float alone cost me 30 usd for that thing, because it was not common...
But lucky me, the whole kit for a P30B, was just 2 USD so i got one for the CG200. It came with everything to refurbish it. I was a bit afraid to remove the top part of the main jet, but with a plastic punch i was able to take it off with ease. The new part was a bit longer, but it did fit right. Refurbished |
05-22-2019, 07:07 AM | #27 |
CSC TT250 guy are they much into mods for PZ30B carb?
I've looked into the cable for that style of switch gear but the solution I got is just OK and needs fiddling to work etc. Really it needs a correct style cable with the elbow and fitting into the switch gear correctly and correct length inner cable. Worst case could be different switch gear without the A1 A2 but that kinda isn't the nicest way. I managed to find 'good enough" solution with some DIY required to make it work "fine" or best I can without the actual bike (Used RX3 switch gear to test fit) |
05-22-2019, 07:11 AM | #28 | |
The Hawk etc might already have a "fast throttle" or 1/4 turn style in it, if not it can be changed without buying a whole new thing. |
05-26-2019, 12:52 PM | #29 |
If you are looking or a Keihin style pilot jet do not buy this Powerzone carburetor.
https://www.ebay.com.au/itm/PZ30-30m...AAAOSwGIZcCU88 |
05-26-2019, 01:51 PM | #30 |
"Dual Cable PZ30B Pumper Carb" does not fit on the Bashan WILL 200 or other similar framed bikes
I'm a sad Panda today Anyone in my area need a PZ30B let me know... I never actually used/filled the PZ30B with gas but I did clean and lube it up (MMO and Neutra 131 mix) getting it ready for service on my Bashan... and I quickly found that the "pumper cable mounting bracket" hits the right side frame no matter what you do
