Old 03-21-2024, 10:15 PM   #1
edwardsjethro   edwardsjethro is offline
Hello
I'm Edwards bought the hawk 250 dlx efi about 2 weeks ago and still haven't ridden it because at 6009rpms the engine cuts out, gotta pop the clutch and feather the throttle to keep her running.
Old 03-22-2024, 08:27 AM   #2
Welcome aboard! That doesn't sound normal. Check that the spark plug is securely set in place. If it has the cheap Torch spark plug, i would replace it with a good NGK plug.
2020 Kawasaki Vulcan S
Old 03-22-2024, 11:50 PM   #3
delzy   delzy is offline
Air leaks around the carburetor, slide cover or intake maybe.
Old 03-25-2024, 07:20 PM   #4
Do©Hawk   Do©Hawk is offline
Welcome, Edwards. Is your Hawk throwing any check engine codes?
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, GPS verified, as equipped: 68 mph (so far)
