Old 03-06-2018, 11:11 PM   #1
Angus67   Angus67 is offline
Angus67's Avatar
Progress! Finally! Rocketa rehab
So i got my 27.5 pilot for my vm26 on my 200cc ohc.
Im at sea level, i have the needle at at the 4th notch. 110 main. Mix is somewhere around 2 turns out.
It now idles steady without choke, im guessing 900rpm. I don’t have a tach rode it through the gears , the clutch is slipping abit, but hey! Huge step getting it to run right Ive tried to post a vid before, but it wont err...take? Idk. It started first kick after i talked to the neighbors for five minutes. Thanks for all the help given here.
On to the next step. New clutch. Its a 163 ohc. Anyone have a direct link?
2006 roketa 200cc
1971 Yamaha xs650
2x 1980 xs650, 1 is a café, other is a chopper/brat
1972 Honda xl250
2x early 90's Honda rf600 parts bikes
more mc junk laying around.
Old 03-07-2018, 04:17 AM   #2
humanbeing's Avatar
Originally Posted by Angus67 View Post
... next step. New clutch. Its a 163 ohc. Anyone have a direct link?
Any pic? big/ small hole | regular/ oversize | 4/5/6 bolts ... as https://item.taobao.com/item.htm?id=39837275401 said
Most of time change fraction (wear limit: 2.6mm) ONLY will get the job done http://www.mychinamoto.com/forums/showthread.php?6812
Old 03-07-2018, 08:48 AM   #3
Angus67's Avatar
Pics for your pleasures
File Type: jpg 38B89862-19E3-424B-A450-6D6E5DDB2DB5.jpg (20.0 KB, 117 views)
File Type: jpg B99F6C5C-9C4A-4898-9E59-C96CD7B8F039.jpg (20.1 KB, 117 views)
File Type: jpg 668A99D7-A8DE-41E2-9390-F973235FFCD2.jpg (20.6 KB, 120 views)
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
Old 03-07-2018, 09:24 AM   #4
Glad to see you got it running. As far as the clutch, you will need to pull the cover to see what you have and take some dimensions. More than likely it is a 6 bolt clutch with 6 friction disk. You can find them on Ebay. Just search CG or CB 200cc clutch. You should be able to just replace the friction plates.
2020 Kawasaki Vulcan S
Old 03-07-2018, 10:54 AM   #5
Have you changed the oil? If the PO used oil that isn't compatible with wet clutches, you might get lucky with 15W40.
Old 03-07-2018, 02:06 PM   #6
Angus67's Avatar
Thanks. I have 15-30 deisel oil in it. It has no friction modifiers
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
Old 03-07-2018, 11:25 PM   #7
Angus67's Avatar
Woot! It started third kick cold full choke. After warm up on half choke. It settled into a smooth low idle, no choke . Romped around the area for a bit, idle was a bit low after, so I upped it a smidge. Even with a slipping clutch I could feel the front get light. I'm not after wheelies or stunts, but if it can, yeah!
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
Old 03-08-2018, 10:44 AM   #8
Angus, it's time that you showed us the other bikes in your stable. Please consider starting a thread on that.
