Old 02-27-2017, 03:48 PM   #31
nattex   nattex is offline
nattex's Avatar
Uni here also. Very pleased with it so far. Uni's are known to be a quality air filter.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 02-27-2017, 04:51 PM   #32
letsride   letsride is offline
Why get rid of the air box? Why can't I just put that Uni pod filter IN the original modded air box? Just thinking out loud. But I like the idea of my air filter being protected.
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300
Old 02-27-2017, 04:55 PM   #33
I've been thinking how I'm going to do that myself when it come time for a new filter. I should be able to accomplish that with some PVC pipe.
2020 Kawasaki Vulcan S
Old 02-27-2017, 05:01 PM   #34
MDStroup   MDStroup is offline
MDStroup's Avatar
Just going from memory, but some people got junk air boxes from the factory so they wanted to replace/remove it, others probably just like the look.
Old 02-27-2017, 06:28 PM   #35
hertz9753's Avatar
I remember a guy that put a pod in his air box. It involved that pipe and some fittings on each end.
http://www.ebay.com/itm/270761406708...%3AMEBIDX%3AIT
I went the simple route with a K & N drop in filter and rubber weather stripping to seal it because the lip is not as thick as the stock filter.
Old 02-27-2017, 08:12 PM   #36
Rail32   Rail32 is offline
Rail32's Avatar
When my pipe comes in and I install it on the hawk250 there is possiblity of interfrence with air box . Gonna decide at that point on ways gonna be my move.
Either modding air box or going with Uni filter directly on carb . Most likley if I go direct filter to carb I will make spash guards to protect filter from direct water spray . This is just my thinking and may change mind before its all said and done. No worries as I will post pix when done .
Living life to the fullest to avoid regrets later ,,,,or I am a complete loon ! Either way I am good
Old 02-27-2017, 09:49 PM   #37
Well when I put the exhaust system on the new bike, I am going to just use muffler shop wire to get the bends I want, then I will take the pipe to a shop I know of that has a mandrel bender and bend the sucker like I want and get it to fit like the stock pipe. I'm not really into bending the pipe (decreasing the I.D.) to clear the box. I'm not sure how this will play out, until I get another bike and get to it. The pipe is aluminum so bending it the correct way can't be to hard
