Old 08-26-2016, 09:17 PM   #76
cheesy   cheesy is offline
cheesy's Avatar
Man, these tires are bee-atch to mount, even with the tire changer. The problem seems to be the nearly 50 year old rims. The edges are straight, not rolled, and there isn't much of a drop center, so the tire is fighting me the entire time. At least I have two mounted. These took just a tad over an hour which is better than two nights with no success.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 08-27-2016, 01:04 PM   #77
Can you find cheap replacement rims that would be easier?
Old 08-27-2016, 03:35 PM   #78
cheesy's Avatar
If I have no luck this weekend, that will be the next the step. I can check where I've been getting the mini bike stuff.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-27-2016, 06:53 PM   #79
I bet TSC has them.
Old 08-27-2016, 07:03 PM   #80
Bruce's   Bruce's is offline
Probably northern tool and harbour freight as well .
Old 08-27-2016, 07:21 PM   #81
cheesy's Avatar
No need, I got the little jerks mounted. I really want to call them something else, though.
I don't think new front wheels would have been much of a problem. 5" X 4" with a 5/8" bore. The rears, though, would probably be a problem. 6" X 5" running on a 7/8" live axle.
But as I was finally successful, I don't need to worry about it now.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-29-2016, 10:57 AM   #82
We like pics of shiny new tires.
Old 08-29-2016, 02:02 PM   #83
cheesy's Avatar
I don't do shiny, but they are new. Pics this evening.
The front ones were the PITA to mount and the easiest to fill. The rears were just the opposite. One needed the 'Ether Method' to seat, nothing worked on the other one until I unmounted the tire and attacked the rim, again, with an 80gr Roloc. I missed a couple spots on the rim that allow the tire to slide up to seal. Once I got that bit of rust off, the tire pumped right up.
I went through six t-shirts between Friday and Sunday evenings. They were pretty icky.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-29-2016, 02:18 PM   #84
Gotta laugh at the ether method. Yes I have had luck with that with carb cleaner and flats at the work site. last time I just installed those kendas on my mowers, one would not bead up so tried it and got the chicken fur on my right arm. Had to use the ratchet straps to bead it up. There is always some in the workshop getting in trouble taking short cuts , IL be the first to admit it.
Yes , after I mounting mine, you would have thought it was WrestleMania .you get your feet, hands knees, and elbows in on the job.
Old 08-29-2016, 03:11 PM   #85
Nothing like an explosion to get a job done, thats what I always say LOL
'Chicken fur'
Never heard that one before, I like it.
Old 08-29-2016, 03:47 PM   #86
cheesy's Avatar
My arm smoked a bit yesterday, too.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-29-2016, 07:14 PM   #87
cheesy's Avatar
Fronts
Rears
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-30-2016, 10:24 AM   #88
Do the front rims use bearings?
Old 08-30-2016, 11:08 AM   #89
cheesy's Avatar
Cast iron bushings. I bored them out and pressed in bronze sleeves.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-30-2016, 03:04 PM   #90
That should last a good long time. What's next on the project?
