07-28-2014, 03:57 AM | #1 |
OIL drain cap Zong zs200
Good day my friends,
After trying to change the oil on my zong, i over tighten the oil drain cap, with the result to crack it. Is missing drops of oil but i want to ask if the yamaha tw 200 is the same screw? to replace it. Also some interested info about the zong zs200 gy for oils, please i inform you that by mistake i was running the motorcycle with 1 liter of oil for 2 years, after every change of oil. On the side of the right cover is writing 1.3 liters, so do not get stressed when you put some less oil, zong will keep on going! |
07-28-2014, 10:38 AM | #2 |
Hi geo99rge,
I believe the TW200 drain plug is the same. One litre of oil is ok, but it is best to use the window on the clutch cover for oil level.
07-28-2014, 11:00 AM | #3 |
I know but i do not have oil level, is broken, and now i have to take oil out to measure! I glued the oil level with some glue for metals!
The drain plug is more important, thanks for the answer Last edited by geo99rge; 07-28-2014 at 03:12 PM. |
07-28-2014, 03:08 PM | #4 |
hello again i found this not original honda innova and yamaha (cub) for 5 usd from local store. yes cubs generally are very popular in greece as in malaysia and rest south pasific countries due to simplicity. where is the same as tw200 drain plug.
for anyone interested this is the code below image thank you for your help |
07-28-2014, 10:28 PM | #5 |
That drain plug fit properly?
07-31-2014, 01:37 AM | #6 |
Any of the following oil drain plugs will fit the Zongshen 200GY-2 perfectly.
Yamaha TW200 Yamaha XT200 Yamaha XT225 Yamaha TT-R225 Yamaha TT-R230 You can replace your broken, oil sight glass with the equivalent, Yamaha part #3Y1-15361-00-00. You could also purchase a new, right crankcase cover for your Zong from Taobao. http://item.taobao.com/item.htm?spm=...56&ns=1#detail
