Old 04-21-2024, 05:58 PM   #1
MFCDirt   MFCDirt is offline
It's been a while since I last posted. Could not get it to run so it got stored for the winter. It has spark and starts (and then stops) if I put fuel directly into the spark plug hole. The carb was taken apart and cleaned. Other than the holes in the bottom (clearly stored with some fuel), it looked ok. I filled the holes with JB-Weld. It did not work, it started flaking in the bowl. I'm thinking the carb needs to be replaced. What's the best way to find a carb for this "thing"?
Old 04-21-2024, 11:14 PM   #2
Pull the carb and measure the throat in mm. This will show the size you need. Search on Amazon for the size. These small motors usually have a PZ19 or 20 carb. Might be smaller. BTW, if it wasn't clear by the earlier posts, it's not a two stroke. The 650ml is the amount of oil the crankcase holds.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
