Old 04-24-2009, 03:19 AM   #1
czowner   czowner is offline
Bits in the oil, Again!
When I arrived home from work this morning I decided to change the oil as it had been in nearly 2000km. What do I find? Redish brown rubber flakes on the strainer. It's not the crush drive again as the rubbers are black. If I remember correctly the timing chain tensioner blades were black as well. To be honest I can't be bothered with it, I have house repairs to get on with, and a semi classic motor car that wants attention.
Jonathan.
Old 04-24-2009, 10:56 AM   #2
Two good things about that:
The strainer is doing its job.
The particles aren't ferrous.
Old 04-24-2009, 11:29 AM   #3
What's the car ?
Old 04-25-2009, 03:43 AM   #4
Originally Posted by FastDoc
What's the car ?
I think it was sold to you guys in the States, it's a 1988 Renault 11 TXE, that's the top model with manual transmission.
As for the rubber bits I'm tempted just to ride it and see what happens.
Jonathan.
Old 04-25-2009, 11:29 PM   #5
SeerAtlas   SeerAtlas is offline
Hmmm, well it "could" be seal material, or, it might be something coming from the carb manifold. Sure its not black plastic and not black rubber?
Seer
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 04-26-2009, 03:30 AM   #6
Seer
It's definitly rubber, the bits are big enough to feel between your finger ends. It's the dark drown colour that's got me, all the rubber components in the motor are black. The only thing it could be is the valve stem oil seals but I can't see any curvature to the flakes.
Jonathan.
