05-07-2024, 10:32 PM | #4 |
If the bike sits at idle of under 1000 rpm it probably has insufficient pressure for more than a minute. Exact number might be 1250 or higher. I don't mind a 1400rpm idle, but it is probably higher than needed.
Your question slipped through un-noticed, but I thought I would revive it. If you only idle the bike for moments on the trail, 1200 rpm or even less should be OK. Sitting at a red light for a couple of minutes, maybe 1300rpm would be better. I'd like to hear others comments on this.
