11-03-2016, 07:20 AM | #1 |
Help me decide
New member here... Great resource. Pretty sure I'm gonna pick up a Tao Tao 125d or equivalent for my 6 year old and am lookin to get one for myself to putt around the yard. Only have around 3 acres to ride around so don't think I need a 150 but my choices in the 125 range are limited in the bigger rides to the 125f1 Tao Tao or the Coolster 3125d. Both are semi auto. How are those power plants and the semi auto tranny? Or is it better to just get the 150 in the comparable model with cvt? I'm 5'11" 200 lbs. property is mix of hills and flat.
Any advise? Anything else I should be looking at? Kris |
11-03-2016, 08:00 AM | #2 | |
11-03-2016, 12:41 PM | #3 |
taotao
if you do not want to spend much on the atv for yourself... look at the 110 h... 125c model bigger than the 125 d and might suit you instead of buying the larger 150 model.... it is not a cvt drive so it might suit you better... it has a choice of a 3 sprrd with reverse or a forward and reverse..... the 3 speed gives you more power to climb because of th gear coice... both good machines...
11-03-2016, 03:49 PM | #4 | |
Kris Last edited by Kmaz; 11-04-2016 at 10:00 AM. |
11-04-2016, 11:25 AM | #5 |
Welcome, Kris! Thanks for joining us.
11-05-2016, 01:53 AM | #6 |
110 H or 125c
hello... here is a pic of the 125 c .. the 110 h is about the same thing
11-05-2016, 01:55 AM | #7 |
website
Hello go to www.canadattatv.com or www.tao.us
11-05-2016, 01:58 AM | #8 |
wrong site
Sorry .. I ment www.taotao.us look at the cheetah... about the same... USA model..
11-05-2016, 10:13 PM | #9 |
Thanks for the welcome , and the replies .
Kris |
