Old 01-26-2018, 12:28 PM   #1
CrazyHorse   CrazyHorse is offline
CrazyHorse's Avatar
2017 CFMoto Zforce 800 4x4 cooling fan issues overheating
Hi all I have a 2017 CF Moto ZForce 800 which is overheating
the cooling fan does not come on and i have a slight water leak at the water pump.
I did check the fan and it is working as is should it comes on with no excessive draw or drag from worn bushings on fan.
So i know the fan is not the problem, but what to check next in the circuit
Any one have an idea on if the fan is controlled by the computer/control module or is it controlled by its own basic relays and temp switch and or ??
Another question is, is there a place that parts can be ordered from for this machine.
Although i am a bit surprised it has any issues being only 100 miles of very easy use
Any help or advice is appreciated...
