Old 01-20-2017, 10:45 PM   #1
IMPORT_CIRCUS   IMPORT_CIRCUS is offline
IMPORT_CIRCUS's Avatar
My Hawk
Hello folks, just thought I would make a post about my bike.
2016 Hawk 250
I bought the Hawk back in November, so far this is what I've done to her:
Digital cluster
Iridium plug
LED blinkers
OPT7 LED headlight
full exhaust
MSR shift arm
Mikuni clone, (running a 120 main, seems a bit fat though)
air box mod
blinker beeper delete
RK O-ring chain
burrito tube
I have a set of Kenda k760 trakmaster tires I have not installed yet (need DOT rating). also I have some sprockets that I have not toyed with yet.
soon I will do grips and a storage box behind the plate.
I left off some plastic bits, I just did not like the look at all.
please pay no mind to my filthy garage, its winter.
Here are some photos.
Old 01-20-2017, 10:47 PM   #2
a few more
Old 01-21-2017, 07:39 AM   #3
No, way!!!!!
Motocheez has his own line of key rings????!!!
Just kidding....great work on the Hawk!!!
Would love to see a photo of the headlight 'in action' if you can get a photo of it illuminating down the road or a wall or both.
Old 01-21-2017, 10:51 AM   #4
Sport Rider's Avatar
The black looks great!
I want a key ring!
Old 01-21-2017, 05:28 PM   #5
I will take some photos and upload them tonight.
Old 01-21-2017, 07:31 PM   #6
jct842   jct842 is offline
If you have any unwanted light patterns as I did on low beam..... to find where to block them just put your finger over the head light lens. I painted them out. If it is bad on upper left your finger over lower right will knock it out. Mine were on the low beam, high beam was perfect on a klx.
Old 01-21-2017, 07:35 PM   #7
hertz9753's Avatar
Nice looking bike. Those better not be phone pictures or I'm tossing my Cannon camera out.
Old 01-21-2017, 09:04 PM   #8
photos are from a Motorola RAZR V3 flip phone.
actually, from a Nikon D700
Old 01-21-2017, 09:02 PM   #9
Here is the headlight, this is low beam, high beam is a bit brighter but its hard to show the difference. this is as low as I can adjust the light, gotta take it apart and see whats going on.
I'm planning on changing the headlight housing to an old school 7" round headlight at some point anyway.
Old 01-22-2017, 01:57 AM   #10
Wow! That is bright!!
Old 01-21-2017, 11:46 PM   #11
hertz9753's Avatar
Good to know that I don't have to get rig of my camera.
Old 01-22-2017, 03:57 AM   #12
hertz9753's Avatar
October 30 when I brought the bike into the entryway of the house. I did knock over pretty much everything that was on the floor...
I'm still waiting for a picture to see if I'm the only person that needs a hex wrench to adjust the valves. No flash because my camera yelled at me.
Old 01-22-2017, 09:27 AM   #13
pistolclass's Avatar
I needed a hex wrench too. I ended up breaking mine because it is made of plastic. I went to the parts store and matched the thread pitch and got the smallest one on the shelf. If you got my route make certain your new oil plug does not interfere with your inner engine parts.
Old 01-22-2017, 10:57 AM   #14
mine is not hex key, my MCO states 2016.
valve cover was 10mm bolts and the valve adjuster was square from memory,
like the adjustment screw on an Acetylene tank.
I adjusted both valves to .002", dead cold. seems to be working nice so far.
Old 02-23-2017, 04:48 PM   #15
JMM   JMM is offline
Does the motor really redline at 10k?
And second question, For anyone hat has that cluster. How long did it take to come in once you ordered it? Thanks.
