Old 11-26-2014, 09:34 PM   #1
TheGageinator   TheGageinator is offline
Starter Sprag Clutch issues
I started having a problem with my starter clutch recently. engine is a 163FML 2007 SunL atv.
My atv would not start after i shut it off the other day. the starter just spun. i push started it and drove home.
after cool down, the starter would still just spin. didnt turn the engine over.
I pulled the flywheel cover to see what the problem was. I noticed that the starter clutch(sprag clutch) was spinning freely in both directions.... it only supposed to go one way.
i used my impact wrench to remove the flywheel bolt. when i did, i noticed that the sprag clutch was now working perfectly! yay! i thought maybe something got stuck in it and the impact got it loose.
i put the quad back together and drove it the next day. the starter was working great. after getting home and shutting the atv off, i tried to restart it. the starter just spun.... i removed only the flywheel nut cover and used my impact on the bolt for 1 second. then it worked like it should again and the starter engaged.
has anyone experienced this issue? how hard is it to replace the flywheel and or start sprag clutch?
below are pictures and videos
the initial problem
after i impacted the flywheel bolt it was normal
This bolt was very tight. I used my impact to loosen it and remove it. Then re-installed . I did not remove the Flywheel
Old 11-26-2014, 10:43 PM   #2
humanbeing's Avatar
Universal "9" http://item.taobao.com/item.htm?id=38702236969
How to install :
http://gd1.alicdn.com/imgextra/i1/83...!839374980.jpg
1. Apply thread locker as picture (too much WILL had difficulties when un-bolt !!!)
2. As pic but NOT stone tight yet because flywheel hole maybe bigger than normal (un-balance)
3. Re-install rotor / Check movement are OK.
4. Tighten the bolts. Re-check everthing is OK.
Old 11-26-2014, 11:17 PM   #3
Thanks for the input, HB.
I've never seen that specific symptom, but it makes sense that the one-way clutch bolts backing out is the cause. Loctite to the rescue!
Old 11-26-2014, 11:39 PM   #4
humanbeing's Avatar
... makes sense that the one-way clutch bolts backing out is the cause. Loctite to the rescue...
Starter clutch ALWAYS need thread locker. A guy ended up as http://www.mychinamoto.com/forums/showthread.php?7142 when changing parts.
Old 11-27-2014, 12:33 AM   #5
thanks human being. Do you guys have any advice for getting the flywheel off? I remember seeing a special tool once, but maybe I can use a 3 Jaw puller or something?
Old 11-27-2014, 01:59 AM   #6
humanbeing's Avatar
Typical "CG" family uses http://item.taobao.com/item.htm?id=15493827363
3-in-1 / 2-in-1 / holder ... http://shop35604947.taobao.com/category-674194625.htm
Non-std solution when special tool (puller) don't work. http://translate.google.com/translat...t_258826_1.htm 3 jaw + mallet
Old 11-27-2014, 10:44 AM   #7
I'm in the USA. I found this one in eBay. It looks like it may be reversible to to 2 different sizes. http://pages.ebay.com/link/?nav=item...120159&alt=web
Old 11-27-2014, 10:45 AM   #8
Are you saying that a lack of threadlocker can shear the woodruff key?
Old 11-27-2014, 10:47 AM   #9
That one looks like it will do. Can you measure your flywheel to be sure?
Old 11-27-2014, 10:49 AM   #10
I could measure it but I'm not sure I want to take it all apart again. I may just gamble and buy the tool. It is pretty cheap. I will definitely update with pictures when I get the tool. I just ordered it
Old 11-27-2014, 11:12 AM   #11
I recommend some lube on the threads before use. The tool steel isn't the best, and it can strip easily.
BTW, if yours is the model with RH threads in the flywheel, a metric bolt of the correct size will pop the flywheel off.
Old 11-27-2014, 11:45 PM   #12
Thanks I'll remember that.
I ended up going with these 2 tools.
http://pages.ebay.com/link/?nav=item...336233&alt=web
I drove the atv for about 4 hours today on some trails and around my land. I had the problem intermittently. When it gave me the problem, I popped off the 4 some cover screws and just impacted the Flywheel bolt for a second. Then it would start right up. I'm excited to get the tool in so I can get my quad ready to take hunting.
Old 11-28-2014, 10:53 AM   #13
That's a fair price for two tools.
Old 11-28-2014, 05:11 PM   #14
flywheel clutch
On the back of your flywheel... there are rollers.. if these rollers get stuck they will not fly outward t o catch the shaft to turn it... remove the flywheel... with your tool.. and check the rollers for flat spots.. this is the problem.. make sure they look good.. this is how the motor turns over when the starter turns it... as the starter gear is what causes the motor to turn to start.. and then stop turning when the motor is running and you release the starting motor from trying to start the motor.. there is no bendix like a car starter to kick in & out
ABIBABA ATV ETC
Old 11-28-2014, 07:07 PM   #15
Thank you for the great reply! As soon as I get my tools in the mail. I'll take lots of pictures of the procedure
