11-08-2017, 10:01 PM | #137 |
There is a saying, "A picture is worth a thousand words!"...ARH
11-29-2017, 09:41 PM | #138 |
Update
Took a little work but I got the exhaust to fit good. I still have to make a bracket to support the muffler. I cut open the headpipe and removed the converter. I cut off the spark arrester and drilled big holes inside the muffler to increase flow. Had to notch out motor mount, cut foot gaurd bracket off the frame and remove all the brackets on the muffler. Running major lean(cold Weather doesn't help) I can tell it def has more power. Def louder but no crazy loud which is nice. I picked up some lighter aluminum front wheels. If anybody has rear 8" aluminum wheels I'd be interested in buying. Has to be blaster bolt pattern. This project has come along way since I got it. Still needs a bunch of work but it a fun project! Think I felt the clutch slip :( Big thx to Kirbo
11-30-2017, 07:37 AM | #139 |
Looks like it was made for it. Now that it can breathe just need the right size jet.
12-01-2017, 12:36 AM | #140 |
Glad to see that Hawk exhaust was put to good use! It looks like it was from the factory! Keep us posted on your progress!
12-01-2017, 09:59 PM | #141 |
Will do! ya I'm really surprised it worked out so well. Wish they made an performance cam for this engine. Next I have to find some aluminum rear wheels.
