03-13-2017, 08:13 PM | #527 |
Rear lower fender broke
Hi guys!
Don´t know if your CSC RX3 bikes have this "rear lower fender", but I´m sharing my experience just in case. A couple of days ago found this fender loose someway, even when the two bolts where properly torqued. After removing those bolts found the inner 3/8" pipes, that holds the plastic frame, where broken just after the soldered joints. Tomorrow will look for a welding shop to fix this. Regards, Juan Carlos.
______________ - ex Honda MB100 (1981) - ex Honda Nighthawk 250 (1991) - ex Honda Storm 125 (2009) - ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb) Benelli TRK 502 (2018) |
03-13-2017, 11:13 PM | #528 |
Thank you for sharing that, Juan Carlos. The CSC bikes don't have that, but I have seen it on RX3 pictures from other countries.
03-14-2017, 12:26 AM | #529 |
looks like broken from vibration.
03-14-2017, 10:01 AM | #530 |
Agree. But I´ve roded around 200mi dust/gravel only, of 3500mi total.
03-14-2017, 11:02 AM | #531 |
Hmmm.... I know we've all read here before about dirt or something in the switch causing the stalling problem. I wonder if you had an exaggerated version of the same problem?
03-14-2017, 02:02 PM | #532 |
just replaced it (pulled the left side plates and lifted the tank to get to the plug) . Its just a 2 wire switch, in a bind you could put a toggle switch or twist the wires together if you were out on the road somewhere stuck. theres 2 bolts holding it in from the bottom.....mine was missing one. has 2 now.
Wingless Hawk, 2016 orange RX3, 97 wide glide,2003 KLR |
03-14-2017, 03:37 PM | #533 | |
03-15-2017, 06:46 PM | #534 |
Rear lower fender broke, part 2
Today got the repairings at the welding shop.
I´m not 100% satisfied with the job done ; will see how it performs in time. Probably next time I´ll try welding by myself Just applied a layer of Paint to avoid rusting: And set it back in place : Regards, Juan Carlos.
03-15-2017, 10:32 PM | #535 |
looks like they were letting the new guy learn how to weld
03-16-2017, 10:08 PM | #536 |
Rode mine to work today.....was 16 degrees F on the way in this morning
03-17-2017, 11:22 AM | #537 |
A you got heated gear Huck? Once it gets to 42 or below I wear mine!
2017 BMW F800GS Adventure |
03-17-2017, 05:12 PM | #538 |
Nope, no heated gear, just the heated grips on the RX3...but my commute is only about 20 minutes
03-23-2017, 10:52 AM | #540 |
Wow! They have them on the floors now! Have they been out long? What did you think?
