11-08-2015, 05:42 PM | #1 |
need help with wiring
Just picked up a basket case wildfire 200cc has one of those Lifan clone motors.
Anyway i'm not getting spark. Ignition switch is missing and toggle switch is there. There are 2 wiring harnesses coming out from crankcase one has six wires but only one is attached. I'm going to guess that is for the lights or charging The other plug has 5 wires. blue/white, pink , yellow, green/wht, black/red??? Anyone know which wires to test for resistance/ohm?? and the values it should be?? |
11-08-2015, 06:33 PM | #2 |
IIRC there was a Lifan importer in Seattle who had wiring diagrams on the website. Hooper?
Happy to serve. |
11-08-2015, 07:09 PM | #3 |
It has wire rectifier yellow,yellow, red, green. i'm guessing yellow is a/c cuurent from stator?? red must be to battery?? What is green?? it looks like it might be grounded through housing.
11-08-2015, 07:10 PM | #4 |
IGN ht coil: http://www.sanxin.com.cn/info5/index.asp?id=20
--- CDI http://www.sanxin.com.cn/info5/index.asp?id=16 --- Typical wiring: http://www.sanxin.com.cn/Exhibit/exhview.asp?pid=5 IGN source coil (EXT) sometimes F*** in older chinese bike (Honda shop manual always tells at least 100 volt / From my rusting memory it's somthing ~4xx ohm) in that case plug a DC-CDI bypass it is the quick solution. The chance of trigger/ pickup FAil is very low BUT air gap btw rotor maybe f***ed https://translate.google.com/transla...354&edit-text= .
11-08-2015, 11:44 PM | #5 |
Color code:
http://fanyi.baidu.com/transpage?que...to=en&render=1 --- For ref ONLY blue/white (pickup / trigger [+] ) pink (to rec) yellow (to rec) green/wht (pickup / Trigger [-] can be joined to GND in theory ) black/red (EXT | AC source for CDI) The other set is for the gear display.
