Old 11-08-2015, 05:42 PM   #1
kalboking   kalboking is offline
need help with wiring
Just picked up a basket case wildfire 200cc has one of those Lifan clone motors.
Anyway i'm not getting spark. Ignition switch is missing and toggle switch is there.
There are 2 wiring harnesses coming out from crankcase one has six wires but only one is attached. I'm going to guess that is for the lights or charging
The other plug has 5 wires.
blue/white,
pink ,
yellow,
green/wht,
black/red???
Anyone know which wires to test for resistance/ohm?? and the values it should be??
Old 11-08-2015, 06:33 PM   #2
IIRC there was a Lifan importer in Seattle who had wiring diagrams on the website. Hooper?
Old 11-08-2015, 07:09 PM   #3
It has wire rectifier yellow,yellow, red, green. i'm guessing yellow is a/c cuurent from stator?? red must be to battery?? What is green?? it looks like it might be grounded through housing.
Old 11-08-2015, 07:10 PM   #4
humanbeing's Avatar
IGN ht coil: http://www.sanxin.com.cn/info5/index.asp?id=20
CDI
http://www.sanxin.com.cn/info5/index.asp?id=16
Typical wiring:
http://www.sanxin.com.cn/Exhibit/exhview.asp?pid=5
IGN source coil (EXT) sometimes F*** in older chinese bike (Honda shop manual always tells at least 100 volt / From my rusting memory it's somthing ~4xx ohm) in that case plug a DC-CDI bypass it is the quick solution.
The chance of trigger/ pickup FAil is very low BUT air gap btw rotor maybe f***ed https://translate.google.com/transla...354&edit-text= .
Old 11-08-2015, 11:44 PM   #5
humanbeing's Avatar
Color code:
http://fanyi.baidu.com/transpage?que...to=en&render=1
For ref ONLY
blue/white (pickup / trigger [+] )
pink (to rec)
yellow (to rec)
green/wht (pickup / Trigger [-] can be joined to GND in theory )
black/red (EXT | AC source for CDI)
The other set is for the gear display.
