Old 08-22-2014, 09:44 PM   #1
Zonganaut   Zonganaut is offline
Zonganaut's Avatar
Rear Caliper Fittings for ZS200GY-A
Hopefully a quick one this!
While fiddling around with adjusting my brake pedal I happened to notice that my rear caliper is held on with a large split pin, and only 1 of those at that...
Is it normal to use split pins for this?
I want to add a second fitting as the brake pad is slightly out of position.
Another split pin or replace both with something more robust?
Old 08-22-2014, 10:56 PM   #2
recracer   recracer is offline
recracer's Avatar
Looks like your caliper is missing parts . I just went to the garage to see how mine is ,pulled out parts to show you here . I have never seen parts ,only whole calipers for sale . http://www.ebay.com/itm/CHINESE-GO-K...a224f9&vxp=mtr bracket looks wrong caliper looks right
Old 08-22-2014, 11:07 PM   #3
Zonganaut's Avatar
Hey thanks recracer, very useful to see that. So... looks like some kind of special caliper bolts. Will maybe check in with my local fastener store to see if they have anything that will fit..
P.s. your caliper looks in slightly better condition than mine...
Old 08-22-2014, 11:12 PM   #4
recracer's Avatar
29 bucks for the whole caliper on ebay http://www.ebay.com/itm/CHINESE-GO-K...a224f9&vxp=mtr
Old 08-22-2014, 11:32 PM   #5
Zonganaut's Avatar
Originally Posted by recracer View Post
Double that for postage to NZ
Always hard to find stuff for a reasonable price down here.. hoping I can get some fittings for a couple of bucks!
Old 08-22-2014, 11:53 PM   #6
recracer's Avatar
Wow Ok I did not realize your location . hope you can find some suitable parts.
Old 08-22-2014, 11:54 PM   #7
Zonganaut's Avatar
All good, appreciate time to take pics and find the part on ebay - cheers for that, have a good weekend!
Old 08-23-2014, 01:29 AM   #8
Indeed, you are definitely missing two bolts. I have never seen a brake caliper attached with cotter pins. Good luck finding some suitable bolts.
Old 08-23-2014, 12:08 PM   #9
You should certainly be able to buy a caliper on eBay that is shipped directly from China. The cost won't be prohibitve then, and you'll start with new parts. When it comes to brakes, that's always a good plan.
Old 08-24-2014, 12:39 AM   #10
Zonganaut's Avatar
Thanks guys. Yes, sounds like that could be the go Weldangrind. I'll see if I can find one on Aliexpress.com if no luck on ebay..
Old 08-24-2014, 12:50 AM   #11
Zonganaut's Avatar
This looks similar but not 100% sure how to tell whether it will fit - any thoughts?
http://item.taobao.com/item.htm?spm=...19521424&ns=1#
Old 08-24-2014, 01:15 AM   #12
humanbeing's Avatar
http://item.taobao.com/item.htm?id=22032636663
Old 08-24-2014, 01:19 AM   #13
Zonganaut's Avatar
Awesome, thanks HB! Does it not matter that it says for 125cc not 200cc?
Guess probably not much in it is there..
Old 08-24-2014, 10:42 AM   #14
zingshoen   zingshoen is offline
zingshoen's Avatar
hey, lovely place to live in, worth paying extra shipping for ;-) been to dunedin a few times and up on the volcanic plateau, forgotten what it is called, though.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 08-24-2014, 12:36 PM   #15
I'm betting that it's identical. HB gives us terrific guidance.
