07-04-2014, 02:16 PM | #16 |
Led turn signals are working but the ignition switch is not. I have to kick start la moto because the ignition switch only clicks. I will check this weekend the wires in case something loose. Any ideas? I noticed this problem after modifying for led lights.
Hector Mountrack Vento 2006 |
07-05-2014, 12:07 AM | #17 |
Is the battery fully charged?
Also, check for current "leaks" when everything is off. |
07-07-2014, 11:16 AM | #18 |
Yep, it's fully charged. I will shift the relay and see if it works with the old flasher relay although, in my opinion, this one should not affect the ignition. Will post results the coming days.
07-08-2014, 04:59 PM | #19 |
I found the problem. It was a loose wire in the battery clamp (the thin one connected directly to the fuse). Once it was tightened, ignition relay worked.
07-09-2014, 11:00 AM | #20 |
Good news! Glad to hear you solved it.
07-09-2014, 02:07 PM | #21 |
