Old 03-19-2017, 10:44 AM   #16
ben2go   ben2go is offline
Those voltmeters work really well. A bit hard to see in direct sun light tho.
I installed one in the dash of my CB500X.
Old 03-19-2017, 03:43 PM   #17
BigWeld   BigWeld is offline
BigWeld's Avatar
Originally Posted by green_hawk250 View Post
Installed voltmeter. It is very useful device. It helps to estimate the condition of the battery, or if the regulator or alternator work properly.
Purchased here for $3 - http://www.ebay.com/itm/12V-24V-Car-...oAAOSwNnRYfIKZ
Fantastic idea! You inspired me to snatch one up off of EBay that has 2 USB ports for charging devices on the go. Under $12 shipped, how can you beat it?
Old 03-19-2017, 06:41 PM   #18
pistolclass's Avatar
I just bought one.
Old 03-20-2017, 08:26 AM   #19
I was looking at something similar except it has 2 USB ports. I was trying to figure on how to mount it. Now I know how. https://www.amazon.com/LiDiVi-Waterp...f_rd_i=desktop
2020 Kawasaki Vulcan S
Old 03-23-2017, 08:30 PM   #20
green_hawk250   green_hawk250 is offline
Installed +12V external socket. No more problems with charging the tablet, the smartphone, etc. on the go (with adapter). One may connect a small compressor if a flat tire somewhere on the side of the road. No need to remove side cover to charge the battery periodically during long winter shutdown.
Purchased here for $1.50 - http://www.ebay.com/itm/Waterproof-1...kAAOSwSdZWglPQ
Old 03-24-2017, 01:05 PM   #21
oldscooter   oldscooter is offline
Where are ya'll picking up power for the voltage meters? If I add much more, I'll need to add an aux power block.
2002 Goldwing
2016 Hawk
Old 03-24-2017, 01:06 PM   #22
Azhule   Azhule is offline
I would wire the volt meter into one of the many "Key/Ignition ON" sources... grab a volt meter and find what you need
Old 03-24-2017, 04:17 PM   #23
GeneralTso   GeneralTso is offline
GeneralTso's Avatar
Great write up and my God that thing is clean! I thought mine was looking good smh....
2005 Kazuma Cheetah 200 (Swamp Thing)
Old 03-25-2017, 12:20 AM   #24
This is my schematic with all above mentioned mods. Better resolution pdf is here - http://download1076.mediafire.com/xw...tics+HW250.pdf
Old 03-30-2017, 06:05 PM   #25
Which shifter boot did you order and how long did it take to get it?
Old 03-30-2017, 06:17 PM   #26
Suggestion for your seat; do as I did but add padding between the Coleman Comfort Ride and your seat.
Old 03-30-2017, 10:48 PM   #27
Ordered here - http://www.ebay.com/itm/Yellow-Rubbe...3D112003228434
It took about three weeks, don't remember exactly.
Old 03-30-2017, 10:55 PM   #28
I like your idea, but I am planning totally reconstruct the seat with adding and reshaping foam padding inside. I have already purchased nice marine vinyl cover from Hobby Lobby.
Old 07-21-2017, 01:33 AM   #29
Did you ever get around to doing it?
Old 07-24-2017, 09:16 PM   #30
Please check my thread - http://www.chinariders.net/showthread.php?t=19578
