09-01-2014, 02:57 AM | #1 |
Chain slack for ZS200GY-A?
Just been tightening my chain. Wondered if any of you knew what the recommended slack would be for the ZS200GY-A?
I had a look through the GY-2 service manual and they recommend 15-25mm. Reckon the same for the GY-A? Or being a hondoid would that make a big difference? |
09-01-2014, 03:27 AM | #2 | |
How I go about setting the chain testion on my bikes is... i put a tie down from the axle/swing arm " where you can get it on" to the frame somewhere above it..compress the suspension till the engine sprocket shaft / swing arm pivot / rear axle are in line... tighten the chain till there 10/15mm play in it... after you have done it a few times yer get to know.. don't need to compress the suspension any more.. with all 3 inline that is the longest point the chain needs to fit...
09-01-2014, 09:20 AM | #3 |
yeah, pete s given you the good oil, my speculated guess would be it is more like 30 to 40 mm as on a small XL.
BTW: the specs for the GY-2 are (1) different and (2) i m not sure they are right, coz they are tight.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
09-01-2014, 11:46 AM | #4 |
X2 on Pete's guidance.
The alternative is to place the bike on a stand, disconnect the rear shock and move the swingarm up until the two sprockets and the swingarm pivot bolt are in line. Same result. Pete's tie-down idea is faster.
09-01-2014, 05:04 PM | #5 |
Thanks for the advice guys. Have loosened it slightly, now have just over 1" slack. Feels much better.
Next task: clean carb! |
09-02-2014, 02:51 AM | #6 |
Stumbled upon this handy tool tip from Rallye Raid:
http://www.rallyeraid.co.za/rear-axle-alignment/ Looks like a goer - less fiddly than trying to eyeball the tape measure anyhow! |
09-02-2014, 10:55 AM | #7 |
That's a very good idea! I need to try that trick on my ATV.
