05-11-2016, 10:21 PM | #16 |
It could be just about anything from a bulb not seated correctly in the socket ,to a bare wire ,a bad switch ,bad bulb , or just a bad connection .
05-11-2016, 11:51 PM | #17 |
I assume that for the brake light it could be a bulb I will take apart the housing. But the blinker I am guessing the blinker module is bad. I put a video up on youtube showing it.
05-11-2016, 11:57 PM | #18 |
At this point you are having lots of issues it seems with the harness. I would get my tube of electric grease and go thru all terminals, lube them, and reseat just to insure all connections.
05-12-2016, 06:46 AM | #19 |
when you took the head light off did you unplug all the plastic connectors and look at the pins? mine had one bent over so 2 pins were touching and going into one hole shorting it out. (was my blinkers also)
Wingless Hawk, 2016 orange RX3, 97 wide glide,2003 KLR |
05-12-2016, 09:19 AM | #20 |
Make sure any and all the "sleeves" are pulled over all those "Bullet Connectors".
Also, you might want to consider upgrading to an ATC/ATO style fuse... I have had nothing but problems over the years with those old "Glass Fuses"
05-12-2016, 05:12 PM | #21 |
if i were already having that much trouble, i would be calling the people i bought it from
05-12-2016, 11:57 PM | #22 |
I sent an email to txpowersports and they responded pretty quickly. They were going to send me a starter solenoid before I found out it wasn't that. They are sending me out a blinker module. I didn't have any time to work on the bike tonight. I probably won't be able to look at anything until Sunday.
05-14-2016, 05:05 PM | #23 |
Got a chance to work on it today. Brake light was just the bulb found one close enough and managed to force it in. Does anyone know the actual part # or one that is an exact fit?
MCO came in Friday hopefully I can get it registered this week. Blinkers are the only issue still. Once the new module comes in I should be 100% I still need to adjust the valves hopefully I will have time tomorrow. |
