Thread Tools Display Modes
Old 03-28-2024, 08:09 AM   #3871
cheesy   cheesy is offline
cheesy's Avatar
3' of 13/16" diameter 1144 steel rod and 1' of 5/8" diameter 544 phosphor-bronze rod.
Not as interesting as what Jerry is doing.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 03-28-2024, 10:00 AM   #3872
Bikenut   Bikenut is offline
Bikenut's Avatar
New motorcycle, maybe two. To be continued........
I can't stand the suspense!!!!!
Old 03-28-2024, 12:45 PM   #3873
28" short shovel with a D handle. Contractors stole my old one more than a decade ago while doing some cement work at the old house, and I just need one of these now and then.
Naturally, it doesn't have the steel and wood handle. Instead, it has a cheap plastic handle that isn't tight on the wood stem-moves. I am sure it won't last. And the spade is angled too much, narrow foot tabs, and thinner 16 gauge steel.
I bought my old one about 30 years ago to dig under a sidewalk section to level it. It had nice straight throw action. I might take this one back and keep looking. I am sure that I can find a better one, for at least twice the price
Edit: scratch that. I will live with it. All of the short shovels I find have the new plastic D handle, with exception of a few high end shovels that cost over $100, even over $200
Old 03-28-2024, 03:01 PM   #3874
Might luck out and find one at a yard sale Thumper
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 03-28-2024, 04:50 PM   #3875
Yep, mine
Old 04-02-2024, 11:23 AM   #3876
superjocko   superjocko is offline
I ordered up a set of Kenda K257D Klassic DOT legal knobbies in 3.00x21 front, and 4.10x18 rear. I've already had the heavy duty tubes and rim locks waiting around for my tire change. After a little trail riding yesterday, I realized just exactly how terrible the stock tires on my TT250 are on the dirt, especially the front tire. I had originally planned on wearing them down some before replacing them, but while they're perfectly serviceable on the pavement, they're absolutely a hazard off road.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come.
Old 04-02-2024, 02:38 PM   #3877
Front loading washer shock absorbers
I got a free Samsung washer. Guess what? The phrase 'made in China" is printed on the model/serial number tag. Imagine that. Nice washer/dryer set. Maybe 8-10 years old. In need of some maintenance.
The washer had started to bump and knock and previous owner apparently attempted to replace the shocks ... I could tell someone was in there, and they were not OEM shocks. I bought the companion dryer for $150 and refreshed the rollers, idler pulley and belt. It works great now. He offered me the washer for free, and I figured what the heck, how bad can it be.
Well, it wouldn't drain the barrel in a driveway test...it needed a drain pump (~$24) and a good cleaning. Then it seemed to work fine, but no, it bumped and slammed inside during spin cycle once I ran a load. But the drum was rolling OK (not the spider bracket), and the bearings had not failed. Classic shock failure symptoms.
But, the replacement shocks I got had more than 10mm free play And when the dampening engages, it is weak!
Can you believe this massive freeplay in a brand new shock? All 4 of them did this, some worse than others!
I will be returning them. So here we go again. Trying another set:
Old 04-02-2024, 03:35 PM   #3878
Do©Hawk   Do©Hawk is offline
Thumbs Down
A 1/3 hp sump pump to remedy my flooding basement......the float switch shorted on the old one. I was watching it spark under 1 1/2 ft of water
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, as equipped: 68 mph (so far)
Old 04-02-2024, 03:42 PM   #3879
J4Fun   J4Fun is offline
65 bags of brown mulch and hopefully I can get in place before my new storm DLX 150 shows up on Thursday…
Old 04-02-2024, 05:25 PM   #3880
Very tolerant circuit breaker
Old 04-03-2024, 06:33 AM   #3881
The GFCI circuit did what it was supposed to. While troubleshooting, I tried a different (non GFCI) outlet....that's when I got the brief light show and discovered why the pump quit. At that point the water hadn't risen above the edge of the pit yet. Dumb move on my part, I know, but I panicked knowing that the water was rising.
2022 Hawk DLX EFI
strength!)
Old 04-03-2024, 09:46 AM   #3882
Darkrider   Darkrider is offline
Started working on a deal to possibly buy a '77 Triumph TR7 last night, Going to look at the car today and if i like what i see i will probably pick it up on pay day. Funny enough i talked to the guy about this car about a month ago and he was asking more then i was willing to pay for it at the time. He was asking $4500 but he came back to me last night and said he would let it go for $800. I think he talked to some people between the two points and they let him know what a more fair price was considering it isnt all original any more with having a Ford 2.9 V6 swapped in.
Pic from the sellers post, Will get some tonight when i look at it.
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812 View Post
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
Old 04-03-2024, 12:27 PM   #3883
TominMO   TominMO is offline
"I had to buy it, honey. I saved $3700!"
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 04-03-2024, 02:01 PM   #3884
That would have been a conversation with the ex... But with the new gf her reaction was "And why isn't it in our driveway yet?"
Past bikes:
'10 Gio X33
'80 Honda XL185S
Old 04-03-2024, 03:18 PM   #3885
Nice!! My dad had a TR7 when I was a young kid and we bought him a second one for Father's day back in the late 90's. Great car, assuming you can overlook the Lucas electricals!
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
