Old 09-11-2017, 06:34 PM   #1
MidMoKing   MidMoKing is offline
Vader 125 draining battery while riding
I have a stock 2016 Vader 125 with roughly 260 miles in it. The bike wont hold a charge. While riding it will drain the battery the speedometer power cuts out then the bike dies and won't star back up. If I charge the battery on a trickle charger I still have to jump start the Vader for it to kick over then it wil run good until that battery drains. Any idea?
Old 09-11-2017, 07:35 PM   #2
Adjuster's Avatar
Your charging system isn't working properly. You need a multimeter to verify. But first I would do a simple wiring check. Go over all the wires and connectors and look for a problem. Disconnect all connectors and check the wires and pins and solidly reconnect. This should be a simple issue to trace out.
Could also be as simple as a bad battery. Again you need a multimeter.
Old 09-12-2017, 12:58 PM   #3
I ended up reading on this forum it's the bulbs that drain the battery so I'm gonna try swapping those out.
Old 09-13-2017, 09:07 PM   #4
sshevie   sshevie is offline
Yes change your head and tail light bulbs to LED that should fix it
