02-04-2016, 02:00 PM | #1 |
Changed Rear Tire: Saddle Height is Too High
Original tire 130/90-15 and 130/70-17 is same in diameter.i used my bike about 4000 miles and changed my rear tire with 17 inch rim.i used a 130/80-17 k761 on rear.it changed the driving geometry of the bike. The rear is about 1.7 cm taller now.And the rear suspension has less working area that isn't better like 130/90-15 original Rx3.
I need some help. Do i have to use a lowering link? Or do i have to higher the front suspension.? |
02-04-2016, 05:58 PM | #2 | |
02-05-2016, 07:53 AM | #3 |
so the tire itself should be only 1" taller in diameter. so that is only 1/2" (~1cm) at the axle.
lowering the bike will only reduce your available suspension travel more. unless you are rubbing the tire on the underside of the seat I would not worry about it. if you find that geometry bothers you then you could increase your sag a little to lower the back or raise the front
-whatever you do, just be awesome. - 2008 Kawasaki Versys - 2016 CSC TT250 |
02-05-2016, 10:57 AM | #4 |
Eat a couple dozen donuts. keeps my saddle low
