Old 06-18-2015, 02:42 PM   #1
Firefighter18256   Firefighter18256 is offline
Help with my front sprocket/oil seal
Was out riding it one day and got a heavy oil leak when i got back home with it and found out the oil was leaking from behind the front sprocket. So i taken the sprocket off and found out the seal was shot. i got a new seal but i think there is a peace missing could any one tell me if there is any thing els that goes behind the front sprocket other then the seal?
I got this atv used so i have no clue what it is or any thing. I think its a sunl sla 110.
Old 06-18-2015, 02:58 PM   #2
Mudflap   Mudflap is offline
Only the seal goes behind the sprocket.
Old 06-18-2015, 03:01 PM   #3
This is what i taken off it
Heres my new one
Is it suppose to have a tight fit like seal the hole or is there suppose to be a gap?
Old 06-18-2015, 03:42 PM   #4
It's supposed to be a snug fit. A tiny spring holds it snug around the countershaft.
Old 06-18-2015, 03:58 PM   #5
ok thank you, i have a gap still but i put gasket seal around it the blue stuff hope that works
Old 06-18-2015, 04:56 PM   #6
Is the gap around the outside? If so, I doubt gasket sealer will hold it. Should be a standard size, probably the same as the old Honda C100 cub.
Old 06-19-2015, 12:36 AM   #7
It should also be the same size as a current Honda XR50 or CRF50. There should not be a gap.
Old 06-19-2015, 12:16 PM   #8
This is what i got http://www.amazon.com/Engine-Seal-Se.../dp/B00OIIS3Q8
and it still has the gap. The numbers even match up with the old one. I have a feeling some thing made the hole bigger because looks like some thing dug into the casing
Old 06-19-2015, 12:19 PM   #9
What are the numbers on the seal?
Old 06-19-2015, 12:26 PM   #10
Tc
17
29
6
29c
Old 06-20-2015, 12:03 PM   #11
In case you're unfamiliar with that numbering system, it means 29mm OD, 17mm ID and 6mm width. Do you have calipers that you can use to measure the hole? Perhaps it is more than 29mm wide, and that was the wrong seal size from the beginning.
