Old 06-03-2016, 12:31 PM   #1
mq1991   mq1991 is offline
Hawk High/Low beam switch
So last night as I was riding home my headlight switch melted.
My high beam still works, but my low beam flickers on and off as the switch vibrates. I opened it up and the switch apparently got hot enough to melt the plastic case and push the contacts apart.
Does anyone know where I could just get the switch? Im no stranger to soldering and I feel that the whole left side assembly is going to be costly.
Thanks everyone!
Old 06-03-2016, 12:45 PM   #2
SeerAtlas   SeerAtlas is offline
Thumbs Up
since its a hawk,search here for Adam's parts website and contact him. rps parts prices are pretty reasonable.
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 06-03-2016, 01:00 PM   #3
Adam Rinkleff   Adam Rinkleff is offline
email some photos to rickypowersports@gmail.com
Old 06-03-2016, 01:11 PM   #4
Thanks Adam, I actually just sent you guys an email about it. What do you need pictures of?
Old 06-03-2016, 04:24 PM   #5
This is the problem guy,
I temporarily just jumpered the two wires. I wouldn't recommend anyone do this for an extended period of time, because now both the low beam and high beam will be active if the switch is pushed, possibly overloading the one ground wire.
Old 06-03-2016, 09:07 PM   #6
dpl096   dpl096 is offline
dpl096's Avatar
Your fix was innovative and fit the need. Well done
― Thomas Jefferson
Old 06-04-2016, 10:03 AM   #7
Torgo   Torgo is offline
Torgo's Avatar
I had kind of an opposite behavior early with my Hawk. When I would turn on the low beam for an extended period of time, I wouldn't have the high beam. If I turned the lights off for a minute or two, it would come back. If I started in high beam, I could switch between the two settings all day long, no problem.
It seems to have gone away by now - I'm coming up on 1500 miles - but that was really the only flaky issue I had originally.
I'm seldom out at night and I always run with the high beam during daylight, so I think I finally burned it into the switch. Guess it all depends which direction the switch melts.
