Old 05-20-2015, 09:35 PM   #1
Nydirtbike   Nydirtbike is offline
Head Scratching apollo 250cc 4 stroke
hey guys i have a question. why when i go kick start my apollo 250cc the kick start doesn't kick baCK UP??? i have to raise it up with my hand. no always but it does it a lot.
what can it be???
the bike prob has only 2 hours on it
thank you guys
Old 05-21-2015, 12:59 AM   #2
The kicker return spring isn't hooked over the mechanism. I can't recall, but you might need to split the case to get it back on.
Before accepting that as truth, drain the oil and remove the side covers. Perhaps you can ease the spring back on using a pick.
Old 05-21-2015, 08:44 PM   #3
weldagrind you don't think some is wrong with the motor?? like compression maybe?
Old 05-21-2015, 08:53 PM   #4
Bruce's   Bruce's is offline
Compression has nothing to do with the kick start returning ,it's done with a spring as mentioned above ,and it has probably become unhooked or possibly broken .
Old 05-21-2015, 09:11 PM   #5
ok
i was worried because read some stuff saying about valve adjustments or rings blah blah.
the bike runs great with the electric start. so should i be worried??
Old 05-21-2015, 11:20 PM   #6
Not really worried ,but if you have warranty get it fixed on their dime ,and your electric start won't last forever then you have nothing but push starting it .
