Old 09-09-2016, 01:15 PM   #316
So you cut it, drilled a new hole and then rounded the end? I want to make sure I'm looking at the right thing....
Old 09-09-2016, 01:33 PM   #317
Huck369   Huck369 is offline
Huck369's Avatar
No, I cut 3/32 out of the middle of the arm, and welded it back together....
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 09-09-2016, 02:53 PM   #318
OH! I see it now. Thanks!
Old 09-09-2016, 05:28 PM   #319
detours   detours is offline
detours's Avatar
Interesting mod, Huck! So does it tighten the friction zone in the clutch lever? As in ... you don't need to pull the lever as much to engage the clutch?
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 09-09-2016, 11:13 PM   #320
Huck369's Avatar
Exactly !!
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 09-10-2016, 04:35 PM   #321
New Front Disk
I decided to do a new front disk, since I feel it may be the weak link in the system for those of us who have the odd front braking issues, like pulsation when hot. I'm sure a floating disk would solve all of the problems...but one's not available.
I read the tutorial for the big front brake for tips and I'm glad I did.
1- As Gerry suggests, flat sand the mounting surface. I found that there were varying thicknesses of paint as I removed it. He thinks this may be causing the pulsation. Time will tell once the Dr clears me to ride again. In the meantime, I'm benched :-(...but I can still wrench! :-)
2- I cleaned the heck out of the new disk with some Awesome and a rag prior to install and it was amazingly clean!....especially compared to the TT250 disks.
3- The mounting bolts are BUTTER SOFT! Even after a heat gun to loosen the Locktite, I rounded two allen holes with my very sharp allen socket, leaning my 230 pounds straight down on them with my air gun. I had to take the grinder to them, get the disk off, then grab the shanks with vise grips.
4- Run a tap down the holes in the rim to clean out the old locktite and whatever else may be in there. Clean them with some brake clean and air. It's an 8mm x 1.25.
5- Upon reassembly, use blue locktite and spin them down till they're all flush and sunk into their homes. Cross torque to 25 NM according to the tutorial (about 20 ft lbs). Any more than this and those buttery bolt heads will want to strip anyway. It must be a built-in "do not overtorque" safety feature! ;-)
Now I can't wait to ride the dang thing...........
Old 09-13-2016, 09:44 PM   #322
madsocial   madsocial is offline
madsocial's Avatar
Where did you buy that? I'm I understanding you correctly, that you bought the TT20 front disc and put it on the RX3? I can't see how that would be better. If it was tested for use on a true dual sport versus a street oriented bike.
Let me know how goes.
Cheers!
Rania aka madsocial
2016 Zongshen RX3 (CSC Cyclone)
Pay it Forward!
Old 09-14-2016, 09:32 AM   #323
Apologies if I sounded confusing. I ordered a new RX3 disk from Ryan that I installed above. I brought up the TT250 disks because on Mrs. 2LZ TT250, they were filthy out of the crate. This RX3 disk came spotlessly clean.
Old 09-16-2016, 07:51 AM   #324
madsocial's Avatar
LOL it's okay! Thanks for clearing that up.
Off the subject of brakes, I had a pin come off my side case while I was on my trip. The great folks at CSC sent me replacement. Now to figure out how to put it on.
Cheers!
Rania aka madsocial
Pay it Forward!
Old 09-16-2016, 09:36 AM   #325
What pin is that!? Right or left side.? I guess I better get out to the garage and take a peak....
Old 09-16-2016, 10:34 AM   #326
Juanro   Juanro is offline
Juanro's Avatar
Is that the pin for the case hinge?
Old 09-16-2016, 12:39 PM   #327
AZRider   AZRider is offline
You'll need a small punch to drift the new pin into the hinge brackets. It will take a small amount of force, but quite easily done.
George
2016 CanAm Spyder F3-L
Old 09-16-2016, 01:17 PM   #328
Along with a dab of gorilla glue?
Old 09-16-2016, 01:33 PM   #329
madsocial's Avatar
it's the right side case hinge. The one towards the rear. What an odd thing to come off.
Cheers!
Rania aka madsocial
Pay it Forward!
Old 09-17-2016, 09:11 AM   #330
Glue shouldn't be necessary as it's a friction fit. It's likely that any glue applied would be wiped off as the pin is hammered in.
George
