09-30-2023, 03:30 PM | #16 |
I just want to fix it, learn from it. etc. i tend to anthropomorphize my vehicles.
2022 Hawk 250 |
09-30-2023, 03:34 PM | #17 |
I noticed that you ordered a steel gasket from CSC. You would be using the O-Ring then, but you may want to paint the gasket with some Copper Coat, or something similar. I remember my Dad taking a small roller, and painting copper head gaskets with alluminium color paint of some type, when ever he would work on the tractors.
09-30-2023, 03:55 PM | #18 |
i feel guilty now for even contacting them, but I live on a fixed income and I have a bunch of very needy grand kids and daughters so I am looking to keep things on a budget. Which is why i bought the hawk i love her so. I would put 1000 engines in her to repay the freedom i;ve gotten since may. I cant even explain it. But lets just say, this hawk has change my whole life.
2022 Hawk 250 |
09-30-2023, 04:08 PM | #19 |
That aluminum paint had a large amount of powdered aluminum which acted as a bandaid for badly machined stuff or scratched up. Filled in the tiny gaps and glued the gasket on. Good for reusing old heads etc.
And the old steel shim gaskets needed every bandaid they would get as they were finicky.
09-30-2023, 05:43 PM | #20 | |
10-01-2023, 02:06 PM | #21 |
You just reminded me of my co-worker who has half of his actual kneecap cast in acrylic as a paper weight!
He lost it in a motorcycle crash in his 20's. I feel the same about how much my hawk has given me enjoyment and freedom... but I too definitely need to up my safety game! |
10-01-2023, 02:20 PM | #22 | |
Just don't forget to set the engine to TDC on compression before you take the head off. Also, whilst removing the 4 nuts for the head inside the valve cover, stuff some paper towels or a shop rag into the holes where the pushrods come up. This will help protect against the potential for one of the washers to accidentally fall down into places you don't want it to go.
10-01-2023, 02:26 PM | #23 | |
If it makes you feel better you can use it if desired. Definitely no harm in doing so. I just try to avoid using them because they can be messy.
10-03-2023, 12:41 PM | #24 | |
2022 Hawk 250 |
10-03-2023, 01:20 PM | #25 |
My knee is way better now, and back to more of a normal size. I have been riding a lot more now, but I haven't been back in gravel.
10-03-2023, 01:26 PM | #26 |
Definitely invest in riding gear. I learned my lesson the hard way when I was 18. I did have a helmet on when I crashed. It literally saved my life. Better to have a cracked helmet instead of a cracked skull.
10-03-2023, 06:06 PM | #27 |
I'm glad I never had a moment to get used to not wearing gear, and the least amount of gear I've ever worn on a bike was during the first couple MSF courses. Except for one time when I was camping, I dare say, rode from my site to the host's site with zero gear whatsoever. I felt as naked as a jaybird during that 200 yards at 4mph. I mean I've seen people shatter their collar bone just falling to the side at a dead stop, so I'll take whatever I can get to mitigate the risk and lower the stakes, even just a little.
One of these days I'll have enough for a Helite airbag vest, and then my hand will be forced to full-throttle through Chicago rush hour on a Ducati Panigale V4R. I'm sure it's fairly comparable to my "TT229". |
10-04-2023, 02:55 AM | #28 |
gasket is coming UPS from PSM. I took notes Megadan, don't want to mess this up and also have watched Youtube vids. I think I got this! I am waiting now for speedometer so I can do it all at one time, but I want to ride into the sticks and so I might have to do the gasket before the speedo gets here.
2022 Hawk 250 |
10-04-2023, 06:09 AM | #29 |
add this to your notes. When installing the 3 bolts for the top motor mount, make sure the nuts are on the right side of the bike. If you install them backwards you may damage your fuel tank.
10-04-2023, 01:47 PM | #30 | |
thanks! the package came to my daughters today. looks like they sent a whole gasket set.
2022 Hawk 250 |
