03-08-2016, 02:12 PM | #1 |
Question about carbs and jets
ok, here is my question, and it is for everyone that has re-jetted the stock Keihin clone carb on a 229cc (storm 250).
did it help with the top end speed, and if so was it a lot? today i could not get past 60mph on the speedometer (about 55mph real speed) and it seemed to be from lack of fuel. if i opened the carb any more after 60mph, it slowed down, then i back off a bit, and back up to 60. or is it just the top speed i can get on the 17t/45t sprocket setup? ... it is a sweet bike around town, but like it is now, not much chance it would even see the next town over, at only about 9 miles away |
03-08-2016, 02:37 PM | #2 | |
I went to a 117.5 main jet and it felt like it was just a little better on the top end, but it was only perhaps 1 or 2 mph. mostly it was just seat of the pants that it felt a bit better. |
03-08-2016, 02:47 PM | #3 | |
03-08-2016, 03:01 PM | #4 | |
03-08-2016, 03:15 PM | #5 |
well, i expected to be able to cruse at 55-60, seeing as how the place i bought my bike from said top speed of 80mph, but they were supper far off on that, unless they ment in the back of a truck ... lol
03-08-2016, 03:28 PM | #6 | |
Oh wait....reverse the sprockets....45 front and 17 rear should be about right. |
03-08-2016, 05:16 PM | #7 | |
PS my bone stock gets 61 miles an hour on the Garmin GPS before it hits the ceiling . It seems to be breaking in and cruising a little faster every time I try I will give you another reading report one of these days I have about 300 miles on mine. 230 pound rider on the straight and flat
03-09-2016, 09:47 AM | #8 | |
These bikes are all about gearing and jetting. Do what everyone else does. Bash your cat out, block off the pump, spend the 30.00 on a Mikuni and a pod filter. Put a 115 main and a 30 pilot in it and grow a tooth on the countershaft sprocket and you'll be amazed. Believe me, here in CA, if your bike was legal, I'd make you an offer............ I'd love to have a Storm on my twisties.
03-09-2016, 12:49 PM | #9 |
well, my bone stock storm will not get over about 55mph (60 by speedometer) then it slows down ... i just do not understand how it can pull so well to that point, then just fall on its face ... i want to locate another head, and take a little off of it to up the compression ... i wonder if there is a big bore kit or a stroker kit for the counter balanced 229cc motor ... i just need it to cruse at 55-60 so i can use it on the highway and a smaller rear sprocket is not going to help, or at least i dont think it will
03-09-2016, 01:07 PM | #10 |
ok, now i think the tt250 has the same motor as your storm. Joe said with his side of beef on it and the change in gearing CSC has done {and probably adding in the larger 21/18 combo) Joe says he has personally done i think he said 74mph. and thats on a carb certified bike.
soooo, the speed is in there somewhere, now i am around 250, at elevation around 800 to 1k feet, and tho my hawk is not yet broken in, sustained 55mph right now is NO Problem w the 16/45 setup i settled on. got LOads of throttle left too. oh and thats 55 real mph, not as indicated. The hawk motor is Not a balanced one. The other thing is for you high rev guys, someone pointed out that he thought there is a builtin rev limiter in the stock cdi. The csc mechanic would know if theirs one on the balancer motor placed there by zong.
03-09-2016, 03:46 PM | #11 | |
Also, have you adjusted the valves (ice cold engine) and changed the stock oil out? No need for sadness. Just do what everyone else here does that's well-documented and you'll be happy. That 229cc CG motor is a good one and can perform very well, for a very long time, under the right circumstances, for very little money. Also, there is a break-in period you're supposed ot adhere to.... It's painful and somewhat long but you're not suupposed to go over 5000 rpm for the first 500 miles....general rule. There's hot spots that need to mate like cam and pushrods, etc...
03-09-2016, 05:28 PM | #12 | |
http://www.aliexpress.com/item/Big-b...746771916.html http://www.aliexpress.com/item/70MM-...752847946.html I'm guessing it's what they used to for these http://www.roketa.com/product/product_support.jsp?cateID=2628&sonCateID=0&proID= 2656\ http://www.alibaba.com/product-detai...560316415.html http://www.alibaba.com/product-detai...317546443.html Last edited by nonone; 03-09-2016 at 09:02 PM. |
03-10-2016, 09:00 AM | #13 |
2lz, yes i have done the valves, and it did make a slight difference on my takeoff ... it just pulls so good up to speed that it seems like it should do a lot better at top end ... it may just be that i am not getting up in the rpms the way i think i am in the lower gears, i think i will get the carb and jets ordered next week sense i will have a little more ot on my check, and maybe my new tach will be in by then ... going to rain every day for the next week or so anyway
03-10-2016, 10:15 AM | #14 | |
Going to be raining here for the foreseeable future also. Time to go and tinker in the garage!
03-10-2016, 07:11 PM | #15 |
ok, if i get this carb, does anyone know for sure what type of jets i will need to get for it
http://www.ebay.com/itm/301820210819...%3AMEBIDX%3AIT i have to try something ... i really like this bike, if i could just get it to cruse at 55 or so that way i can take it out on the road past town edit: i will be ordering this stuff next week on wednesday, so any help before then would be supper ... thank you |
