11-05-2022, 12:54 PM | #1 | |
You won't be able to do a tubeless conversion unless you find cast wheels (no spokes). But eliminating the rimlocks is no problem. You can put a thin head 3/8" bolt through from the inside to cover the rim lock hole to protect the tube from blowout. Tape it over as well (plastic electrical tape) with a few layers to blunt any sharp edges. You might be able to find a bolt with no hex head (round heads do exist). Hold it in with a nut for tire mounting, but you can remove the nut after filling the tube. It can be balanced with the nut there, or not.
11-05-2022, 04:30 PM | #2 |
Do the OEM rims have a raised lip in the bead area of the rim or are they completely smooth?
