08-07-2016, 12:39 PM | #16 | |
08-07-2016, 04:18 PM | #17 |
The 200?! http://item.taobao.com/item.htm?id=36366772153 pin Ø15 | Barrel height ~76 [250 pin Ø16 | Barrel height ~79]
08-08-2016, 12:43 PM | #18 | |
08-13-2016, 04:28 PM | #19 | |
Well its about 64 for sure measured it several times. So either its miss-labeled or has a different stroke. so should I get a gasket for the 200 and does anyone know of a dealer that stocks parts in St. Louis MO area ? |
08-15-2016, 06:45 PM | #20 |
Well here's my first attempt at a home made head gasket. I still need to figure out the fire ring probability won't last long without it. I'm going to pick up a hollow punch set for my next attempt I'm trying to get this thing running for Labor Day weekend. Too late to wait for China shipments if I could even find the part. If anyone knows of a US supplier that might have this let me know.
This guy makes it look easy |
08-15-2016, 08:08 PM | #21 | |
08-18-2016, 12:28 PM | #22 |
08-18-2016, 05:28 PM | #23 | ||
Thanks everyone for all your help I let you know how it comes out Last edited by Motohead; 08-20-2016 at 11:17 AM. |
08-19-2016, 06:15 AM | #24 |
if your bore is 64mm I wonder if someone slapped a 200cc in it at some point.... can you measure the stroke, I.e. the hight of the barrel with the piston down in it, as in bottom dead center?
08-20-2016, 02:56 AM | #25 |
yea i'll check it tomorrow
08-20-2016, 02:58 AM | #26 |
head bolt torque
Anyone have a guess as to what to torque the head bolts to? and what is the valve clearance?
08-22-2016, 11:57 AM | #27 |
Just search Google for CG125 specs; that'll answer your questions.
08-22-2016, 12:25 PM | #28 |
if I recall, its around 25ft lb for the head bolts and valves I set to about.008"
04-17-2017, 12:42 PM | #29 |
update
Well its been a wile I never installed my home made gasket but I got Cometic to male me one out of copper. Unfortunately ,I have found the reason the original gasket blew. Their is one striped stud and one striped head bolt I am going to try to heli coil the block but I need to find a set of shouldered head bolts has anyone seen any of these around (disregard the stud that's its screwed on to)
04-17-2017, 02:01 PM | #30 |
Looks the same as those used on the air cooled CG200/250 engines but measurements would confirm that. May also be the same as the real Honda CG engines.
