04-02-2016, 01:58 AM | #1 |
Starts Only In Neutral
I just noticed this the other day. But I can't re-start the bike if I'm in 1st, just holding the clutch in. Is this normal? I'm pretty sure every other bike I've owned I could do this... (unless the kickstand was down, but I usually disable that right away. I'm not prone to catapulting myself like a noob)
04-02-2016, 03:49 AM | #2 |
I still have the original battery in my RX3 and I think I remember it being harder to start in gear. It seems like the battery is week and if left in gear the added drag sucks to much out of the battery and maybe not have enough poop to fire it up????? So I always put it in neutral. rj
Live Zong, and Prosper |
04-02-2016, 04:58 AM | #3 | |
04-02-2016, 06:33 AM | #4 |
On my original engine, it was easy to start in gear with the clutch in. With only 100 miles on the new engine, it lurches a bit, but it still starts.
Is this new for your bike?
04-02-2016, 08:07 AM | #6 |
Mine has some friction in the clutch when starting in 1st but it starts. I typically try to start it in Neutral as It can't be much good for the starter motor.
The clutch seems like it's engaged just a little bit even when the lever is pulled in. The engagement point on mine is right at the end of the lever throw. |
04-02-2016, 04:49 PM | #7 |
OK, I did notice that there is wiring going to the clutch lever. Is there a way I can bypass this or add a jumper?
Think about how impossibly difficult it would be to have to keep finding neutral every time you stall out on a technical rocky trail. I'd probably just rage quit and leave the bike there. I've never been too thrilled with the clutch lever, or it's odd engagement point in the friction zone My hope was that new adjustable levers would cure that. Perhaps, my issue is that I am not able to pull the lever far enough, and thus it it's keeping me from hitting the starter? |
04-02-2016, 04:53 PM | #8 |
if you have a meter you could ohm the switch out and see if its working.
04-02-2016, 05:39 PM | #9 |
The clutch safety switch should be fully closed with the lever pulled just slightly. You can see the little plunger when you pull the clutch in.
I suggest first checking that the plunger is moving freely, then check that the connecters are fully engaged. If both those are okay, test the switch with a meter, then the starter diode as Mudflap suggested. |
04-03-2016, 12:27 AM | #10 | |
http://www.chinariders.net/showthread.php?t=15558
04-03-2016, 09:20 AM | #11 |
Bypass the switch with a small, bare wire or even a paperclip. If it starts in gear after the bypass, the clutch switch is suspect. You might find that the wires or even the switch is loose when you do the test. Pinch both plugs slightly and add diaelectrict grease (if you have it) to the connections and reconnect. If the switch is loose, take out the screws and use thread lock when you reinstall.
