Old 03-17-2016, 10:53 PM   #1
jbfla   jbfla is offline
Naked RX3
Well, not completely bare.
It was time for another valve check/adjustment.
So while removing panels, I decided to go all the way.
No plastics, no cases, no case guards, no engine guards...
I hope I remember how it all goes back on.
What do you think?
A TT250 with radiators and fuel injection?
You may notice the left fork guard is still attached.
The lower bolt holding it on was so tight that the end of my hex wrench broke off in the socket head bolt, leaving me no way to remove it.
I'll try to drill it out, but that's a job for another day...needed to go riding.
jb
2014 XT 250........
Old 03-17-2016, 11:20 PM   #2
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
Might need to lose the beak and windshield too. Then it'd be a Street Fighter RX3
(Don't forget to relocate your rear fender flap with one of those high and tight plate holders)
Old 03-17-2016, 11:29 PM   #3
Jay In Milpitas's Avatar
I like it, JB. Noticed it when I did my first valve clearance check and decided to pull the plastics to check all hardware security and wiring routing. I'd be fine if Zongshen left the forward plastic off and had a smooth sided tank.
I noticed the mount for the beak would be a nice starting point to mount a bikini fairing.
Old 03-17-2016, 11:52 PM   #4
Jbfla. Looks a little more beefer than the tt.
Also since the covers are removed, buy a different color of that removable spray paint and experiment with a different color. They say it peels right off. See how it works,, or not
Old 03-18-2016, 12:05 AM   #5
rjmorel   rjmorel is offline
rjmorel's Avatar
Weight that puppy before dressing her again JD, We just gotsta know, rj
Live Zong, and Prosper
Old 03-18-2016, 12:32 AM   #6
Eco Mouse's Avatar
Well, I guess this technically has to be the fastest one. Damn!
Old 03-18-2016, 01:38 AM   #7
detours   detours is offline
detours's Avatar
Looks good. Better than I would have thought! Now just lose the beak and clean up the tail and you'll be set!
Red 5 standing by!
2014 Ural Patrol
Old 03-18-2016, 03:38 AM   #8
Indeed. Thanks for taking the time to post the interesting photo of the Naked Zong.
Old 03-18-2016, 11:58 AM   #9
Originally Posted by Eco Mouse View Post
Might need to lose the beak and windshield too....
...Now just lose the beak and clean up the tail and you'll be set!
If everything were removed, it would be totally naked!
jb
2014 XT 250........
Old 03-18-2016, 12:00 PM   #10
It is noticeably quicker off the line.
I'm usually a conservative rider, but the lighter weight did encourage a more aggressive throttle.
jb
2014 XT 250........
Old 03-18-2016, 12:09 PM   #11
I started to reassemble all the parts this morning when I remembered there is a DOT weigh station less than 10 miles away.
This is the weight slip for the RX3 as seen in the above pictures:
The RX3 had about 1/2 tank of gas,
No plastics, except windshield and beak, and left fork protector
no cases, or rear case guard
no engine guards
It did have a small tankbag and GPS...2#
and the optional center stand:
jb
2014 XT 250........
Old 03-18-2016, 02:42 PM   #12
rjmorel's Avatar
thanks jb, now we know. and that was pretty close to what I guessed going from what has been said about all the bags and guards adding about 50 lbs to the bike. She's no Twiggy, but more like an 250 Oprah rj
Old 03-18-2016, 04:10 PM   #13
Longboarder1968   Longboarder1968 is offline
Thumbs Up
jb
How much did it reduce in weight from stock? 20/30/40lbs? Like the look may try it myself. Thanks for the pics.
Old 03-18-2016, 04:21 PM   #14
I didn't do a before and after.
It has been reported previously that the cases and guards weigh about 50 pounds.
jb
2014 XT 250........
Old 03-18-2016, 10:58 PM   #15
Louis Angel   Louis Angel is offline
Louis Angel's Avatar
I did not know those RX3's weighed so much. Just does not look like there is 360 lbs of material there. My Vulcan 500 is right at 400 lbs, but looks like afat pig compared to the 270ish lb. CRF230L sitting next to it. :-D
" If it ain't broke, I can probably still fix it!" ---- Tim Allen
