Old 01-28-2007, 05:38 PM   #1
frostbite   frostbite is offline
Honda XR200 tank compatibility
A local guy has some parts from an 83 XR200 for sale. I was wondering if anyone knows if the tank will bolt up to a 200GY-2? The capacity is a bit greater and I'd like to get rid of the plastic drag on the stock Lifan tank.
Frostbite
"The beatings will continue until moral improves"
Old 01-28-2007, 06:44 PM   #2
bfe71730   bfe71730 is offline
Send a message via MSN to bfe71730 Send a message via Yahoo to bfe71730
It may work with a few mods, the hondas tank has one bolt at the rear center and it slides inplace on 2 round rubber pieces at the front, just about in the same position where the china tank mounts. other problem would be the seat, it sits higher up on the tank than the hondas if I remember correctly.
2004 KAZUMA CHEETAH 200
2001 Yamaha Big Bear 400
1986 Honda ATC 250ES
1983 Honda ATC 200X
1974 Kawasaki KE100
Old 01-28-2007, 07:05 PM   #3
ob1   ob1 is offline
If I'm not mistaken, the '83 XR2 had a pillow type seat, no attachment to the tank.
Doesnt the Lifan have a pin on the tank than engages a slot on the front end of a banana style seat?
Sounds like you might generate seat problems with the tank switch.
Old 01-28-2007, 11:23 PM   #4
Jet_Tech   Jet_Tech is offline
The 200XR tank will not even stratle the frame, I pulled the tank off of the old junker in the back yard and tried, even if you modified it the seat would have to be cut. Stick with your original tank and make frequent stops.
Old 01-29-2007, 08:15 AM   #5
ob1   ob1 is offline
What is the capacity of the china tank?
I think the '87 and up XR200 is 2.2gal, and uses the pin/slot seat interface.
It bolts to the frame at the front, and rubber straps at the rear center under the seat.
Old 01-29-2007, 05:47 PM   #6
Ferrit   Ferrit is offline
My search shall continue. I'm looking for 4 to 5 gal. capacity. As for stopping more frequently that only works when you are riding in areas with more frequent stops. I tend to wander away from inhabited areas, especially out west.
I'm thinking of a poor man's Dakar kind of bike.
Old 01-29-2007, 09:14 PM   #7
mdsuave13   mdsuave13 is offline
Send a message via AIM to mdsuave13 Send a message via Yahoo to mdsuave13
thats how i am feeling about it. haha. I want to get at least 300 miles of range...
