Old 10-13-2014, 07:49 PM   #136
Originally Posted by katoranger View Post
New battery has already failed. Little screen not working.
Not surprised. It seemed too good to be true at that price.
Old 10-13-2014, 07:51 PM   #137
While I had it apart in the lab I discovered why the sprockets are alittle out of alignment. The whole swingarm is moved over. I noticed one of the upper suspension links had an angle to it.
Also need to work on the forward neutral reverse box. It has a hard time staying in forward.
That video was good fun to watch. The girls are obviously having a great time on your property. The tire swing completed the picture nicely.
By angle, are you saying that the upper suspension link is bent?
Does the forward / reverse box use a cable or lever?
Old 10-14-2014, 11:18 AM   #138
katoranger's Avatar
I have not confirmed what is out of alignment. It has been this way since it arrived.
The reverse box uses a cable. I think it is stretched as I have the adjustment maxed out.
Yesterday the battery started it right up, but the little display is not working. Seller said they would replace it. Just need to ship it back.
Old 10-14-2014, 03:10 PM   #139
...Yesterday the battery started it right up, but the little display is not working. Seller said they would replace it. Just need to ship it back.
I'm glad the seller is giving you good customer service, Allen.
Old 10-14-2014, 04:57 PM   #140
katoranger's Avatar
I still have the old battery. It can go back in while I wait for a replacement.
Old 10-14-2014, 07:51 PM   #141
Does the cable hook to a spring?
Good news that they'll replace the battery. Are they paying shipping?
Old 10-16-2014, 05:09 PM   #142
katoranger's Avatar
They are sending a return label for the battery. I just have to fill out the form.
The cable attached to a lever that defaults into the reverse position. The lever is spring loaded. The cable adjustment is maxed out and still does not pull it all the way into forward.
Old 10-17-2014, 07:43 PM   #143
Is the cable stretched too far? I've had that happen with parking brake cables.
Old 10-20-2014, 09:01 AM   #144
katoranger's Avatar
I think a new cable is the fix. Seems that it is stretched too much to keep it in forward.
Old 10-20-2014, 11:08 AM   #145
Can you shorten the cable, hillbilly style? I once had a Mercury Sable with a brake cable stretched beyond what could be adjusted. I loosened the cable as far as it would go, which had it laying on the ground. I put a small loop in the cable, secured it with a small cable clamp and loctite, adjusted the cable and called it a win.
Maybe you could shorten the cable with a knot or two.
Old 10-20-2014, 08:18 PM   #146
katoranger's Avatar
I am thinking so since the cable works otherwise.
Old 11-08-2014, 07:31 PM   #147
katoranger's Avatar
I crimped a lock washer around the end of the cable and it works fine again.
Old 11-10-2014, 11:10 AM   #148
That's creative; hadn't thought of that.
Old 11-10-2014, 10:08 PM   #149
katoranger's Avatar
Recycled from leftovers.
Old 11-16-2014, 05:38 PM   #150
katoranger's Avatar
Didn't take any pictures, but we got some time riding in the snow and pulling sleds. Yard is covered with about 2 inches of snow.
